Allis 185
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Topic: Allis 185
    Posted: 14 hours 42 minutes ago at 2:21pm
Does anyone have a handy part number for a block heater that'll fit in where a soft plug goes?Thanks
Gary(VA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 36 minutes ago at 2:27pm
There’s a spot on the right side of the block towards the rear with a plate and two bolts. Agco sells a factory one for that location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 31 minutes ago at 2:32pm
Thanks,found a KATS 30208 that looks like it will work.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 15 minutes ago at 2:48pm
Yes, that Kats number fits my AC185 and 200. Nice thing is it's 1000W another brand is only around 600W. I can't think of brand or number.
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 51 minutes ago at 5:12pm
PaulSamwel
Here is my 185 which has the block heater installed on the RH side of the engine left of the fuel filter.  The tractor was delivered new to our farm in 1975 with the block heater installed, probably by the dealer.  Not a great close up pic of the area, but you can see the electric cord hanging down just in front of the starter
Hope this helps with your project
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 20 minutes ago at 5:43pm
Nice tractor!Looks like the one you have is above and to the right of the starter.The one I'm thinking of goes a little farther back in place of the plate towards rear of engine and above starter.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 39 minutes ago at 7:24pm
Super nice 185 and incredibly close to looking like  it just came off of the Milwaukee truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 32 minutes ago at 8:31pm
Lynn Marshall
Thanks.  I will never forget the day it arrived at our farm, on the Dealers truck.  Over time, rear tires replaced, new seat exactly the same, front tires upgraded from 7.50 and rims reversed, paint job and decals, every thing else factory (a few filters/muffler along the way).
Paul Samwel
I can see the access port you are planning to use.  The block heater will cause convective flow in the coolant passages to warm up the engine metal everywhere the passages go.  The engine metal will conduct the heat really well in all directions.  One port location might be slightly better for overall heat transfer result, but the top of the engine, and the combustion chambers should warm up plenty to achieve a good starting condition.
Other readers might have more info to share on best location for the heater element
My experience with block heaters, like the one on my 185, and the external tank type on my D17 III Diesel, is they work very well, heat the engine up to very very hot (close to operating temp) so starting is like a hot day in July!!!
Good luck with your install
This page was generated in 0.154 seconds.
