Allis 172 Rotary Mower questions.
JayD-17(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Topic: Allis 172 Rotary Mower questions.
    Posted: 27 Jun 2024 at 11:34am
Got a 172 late model (Laporte built) rotary motor from a local auction and it looks like blade replacement is long overdue.
I have no idea whether these blades are old Allis brand or something someone threw in there that was close enough. Agco parts books don't give dimensions and NOS parts #'s aren't much help anymore.
I've measured the less beat and mangled blade and come up with 23"L x 3.5"W x 0.5 thickness.
They have a drop or offset of 2" or 2.5 counting the thickness of the blade.
Doing a google search,  I have not had any luck so far finding blades with these exact dimensions....closest I can get are ones that are only 3" wide......so,  I guess thinner ones would/could work???
There are longer ones available of the 3.5 width, but taking some measuresments, looks like 23L" would be the maximum anyway.
Also, does anyone know the style/type and size of the original bolts used to hold the blades on?
On mine, someone took a regular hex head bolt, 7/8 dia. and drilled a hole in the ends for the cotter pins. For bushings, crude scrap metal chunks/pieces, in two haves, were wedged in between. I'm guessing the bolts originally were some sort of big carriage head type as the first plate they go through had square holes but mine got worn and rounded out.
I've been reading through previous posts on this topic going back some 20 years, but have yet to find one where someone mentions what exactly ended up working for them , either with modern part #s or at least dimensions/specs.
Thanks for any help.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 1:11pm
I sold a customer Woods 12892WD blades he said they fix good
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 3:26pm
IIRR, the offset on OEM blades was closer to 3-1/2  -  4". HTH...Wink
Big carriage bolt, with a bushing through the blade, and a cotter pin hole. There is a center bar that went between the 2 bolts, spanning the upper bar that bolts the upper bar to the gearbox.  There was also an option for corn stalk shredding, all of the above (carriage bolts actually had 2 cotter pin holes) plus a set of zero offset blades that mounted above the offset lower blades.  IMHO, never needed as one set of blades shredded cornstalks just fine...Wink
Edited by DiyDave - 27 Jun 2024 at 7:22pm
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 5:21pm
I am kind of new to rotary mowers, but been lead to believe the standard ware is better than grade 8. And needs to be replaced at ever blade change. I want to say the bolts from over price it cause it's green bolts for a 7 foot cutter(John Deere) were just over $10 a piece. But that was per covid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayD-17(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2024 at 12:37pm
I looked up the Woods part #. Those Blades are an inch longer at 24" I got under there with a yard stick and 24" blades would almost hit the deck sides, especially where it starts to taper inward toward the back. There are blade scrapes and scars in these spots....likely why the previous owner went with an inch shorter.
I'm thinking the original blades were 4" wide though, as the reinforcement plates the blades sandwich between are this wide.
What is the significance of a greater offset , other than putting the blade ends closer to the ground?  If the original offset was closer to 3 to 4", that seems like it would put the blades down near the edge of the sides of the deck and make them more likely to hitting things like stones sticking out of the dirt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2024 at 3:31pm
lower offset means more room upstairs, for the flow of cuttings out the back. Also more vacuum effect in downed grass.  You can also set the height, to compensate for the lower blades.
I would get the 24" blades, and some new bushings and pins, mount them and see if they hit.  If they don't hit, take them out for a test cut.  if at any point they do start bangin, you can always cut a little off with a chop saw...
Check the ORC, on the drive line to be sure its operating correctly.  You should be able to hear it clicking, when you step on the clutch, at high rpm, as the mower starts to slow down.  Also check the rattle clutch, fwd of the ORC, on the drive line.  Don't over grease the rattle clutch, or it will give you all kinds of trouble...Wink
