Allis 170 corn picker
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Topic: Allis 170 corn picker
    Posted: 01 Mar 2020 at 5:11pm
Would an Allis 170 picker on a D17 pick today's 200 bu corn yeilds? I am looking at picking 800-1000 bu per year. I know I might have to run in first but for that little bit it would not matter.  I have a good Deere 300 pull type but always liked the mounted better. Dad had a New Idea 319 on a series II D15 and I have a nice Deere 237 mounted in the shed that I parked because it shelled to much corn on the ground. The Allis with the plates above the rolls should not shell as much. I have also considered an IH 234 if I could find Deere 3020-4020 brackets. Thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 5:24pm
It's all about tons of material per hr. If you can go slow enough, it will work just fine. Back in the day if it could handle 100 BPA corn at 3 MPH, it would today handle 200 BPA at 1.5 MPH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 5:37pm
At that slow of speed are the gathering chains going to breaking the stalks off before the stalks reach the snapping rolls? I have seen where the chains start pulling the corn up by the roots before it is far enough into the rolls. Anyone with experience? Thanks Tom
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 7:55pm
Pick headlines with your mounted picker but keep your JD 300 to do some serious corn picking !!!
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 3:20pm
Hi Tom,
Was out your way a few weeks ago.  Almost thought about stopping by again but didn't have the time.
As far as the picker, yes it will pick the high yields but it is really slow going.  You will save a lot more shelled corn, probably more than any other picker.  They do not husk that well either and are a very dirty machine to run.  I bleed orange and enjoy my picker but if I were you Id do what Marlyn said and pick the end rows and use the pull type.  Otherwise keep an eye out for a 234 IH.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 5:35pm
I see a few 234's each year but have not been able to find the brackets for a 3020 or 4020. Every time  I go to the sale at Waukon I think I should come and see your equipment. Nothing new in the way of Allis stuff here lately. Might get a clutch in the 15 yet before spring. Tom
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 5:50pm
Never seen a JD pull type "here", all N/I and Olivers. ALL of the mounted pickers were N/I, we mounted-dis mounted one on/off of a D-17 for 14 years :-)
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 7:37pm
Mounted JD picker for 3020 went to scrap for 35 dollars last year, and was shed kept. Should have bought it, but didn't... no JD to mount it on. Ermm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 10:29pm
I had a JD on a WD 45 for several years. If you mount one on a different brand tractor, make sure you have the correct gear for the PTO. It must be matched to your ground speed. I bought the picker at 1 sale and bought the mounting bracket off another guy. I used it the 1st year slipping the hand clutch a lot. He found the correct gear in his shed and brought it to me. The gear speeded up the picker to match the ground speed of the 45.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 7:42am
When Dad quit farming, they had a New Idea two-row unit mounted on a JD 720 diesel.  They'd had it on a WD-45 gas prior to the Deere.  They filled all the corn cribs first with ear corn, then changed the husking bed to a sheller bed and hauled the rest of the shelled corn to town to the elevator.  I was too young to help with any of that, but I remember Dad coming in at night, dirtier than you could imagine.
Gary (sw Wis.) View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 1:12pm
I have a 190 picker mounted on a WD (tractor is to small) that I pick 300 /400 bushel a year with. It is very slow and will plug up if you go to fast but it does work. If I go slow enough it picks good clean corn. It does work better if you wait later into the fall or winter as more leaves and stalk break off and blow away.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 3:39pm
I remeber reading that those old 170 or 190 pickers won national picking contests back in the '60's so in good working order they could not have been too bad of a machine in the day.
Wink
I am a Russian Bot
