All-crop "quiz" page2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: All-crop "quiz" page2
    Posted: 08 May 2017 at 8:43pm
Ok guys here's page 2
7.    The AC cleaning method features air control by:
          ( ) a. Adjustment of sawtooth wind valves.
          ( ) b. Adjustable blinds and shields.
          ( ) c. A simple, non-adjustable system of air pipes.
8.    Proper header balance and weight distribution are assured in the "66" by:
          ( ) a. Hydraulic lift.
          ( ) b. Center suspension balance spring.
          ( ) c. 2 balance springs - one on each side of header.
9.    The lower draper feeds crop to cylinder by taking it:
          ( ) a. Straight back from sickle in a wide, smooth stream.
          ( ) b. Sideways from the sickle to another conveyer.
          ( ) c. Away from sickle in bunches to keep cylinder loaded.
10.    Upper draper is a big aid to feeding because it travels:
          ( ) a. Slower than lower draper to bunch up crop for better shelling.
          ( ) b. Faster than lower draper to comb and thin out crops.
          ( ) c. The same speed as lower draper to prevent under feeding.
11.    Both spike-tooth and rasp bar cylinders are harsh on crops because of:
          ( ) a. Steel-on-steel threshing action.
          ( ) b. Their high speed.
          ( ) c. Their diameter.
12.    The combination wood-steel " step-up" rack in the "66"
          ( ) a. Has 5 steps to provide uniform travel.
          ( ) b. Provides a slow, easy ride for the straw.
          ( ) c. Has 3 steps and 3 removable fish backs.
13.    The steel section of the rack behind the cylinder:
          ( ) a. Moves straw away evenly and helps prevent bunching and back lashing.
          ( ) b. Holds straw back for better separation.
          ( ) c. Has openings in the tops of the cross pieces for grain to fall through.
Enjoy guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 7:30pm
You guys don't want to play anymore
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 10:37am
Last day before I list the next page latter tonight
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 11:56am
Been away from the computer for a few days. I do enjoy these. Thanks
7. A
8. B (not 100% sure)
9. A
10. B
11. A
12. C
13. A (not 100% sure)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 9:29pm
Ok here we go.
7. A. Adjustment of sawtooth wind valves.
8. B. Center suspension balance spring.
9. A. Straight back from sickle in a wide, smooth stream.
10. B. faster than lower draper to comb and thin out crops.
11. A. Steel-on-steel threshing action.
12. C. Has 3 steps and 3 removable fish backs.
13. A. Moves straw away evenly and helps prevent bunching and back lashing.
