all loaded up and no place to go
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: all loaded up and no place to go
    Posted: 26 Jul 2010 at 8:06pm
At least until Thursday night.  I think I left the family jewels out in the backyard yesterday after I got done loading all this weight on.  Decided to try my luck in the 6000 lb. class on thursday as in the 4500 lb. class, all I can get on the tractor is one set of rear weights and nothing more.  I am always spinning out before I come close to loosing power, so we will try our luck up there with the big boys.  Wish there was a class in between, but there's not.  Other then the F & H weights, at least all my weights are AC, even the B frame weights on the sides.
Edited by ChuckLuedtkeSEWI - 26 Jul 2010 at 8:06pm
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:24pm
Looks like you and HaroldOmaha found ALL the rear weights available!  Sure glad I was not available to 'help'!
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:32pm
Actually, Harold has two more on each side then I do.  I did use his method which worked well, in that I drilled a hole in each bolt on the outside of the weight and put a spring clip in it to keep the bolt centered until I got the nuts on, and then took the spring clips out and used on the next set.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:36pm
I know a good hernia doctor I'd be glad to recommend, Chuck. If you keep pullin', you're gonna need one!
are genuine." - Mark Twain
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 8:48pm
Whew! Hope all that lifting works out. Let us know how you do!
WC, CA, D14, WD45
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2010 at 7:18am
It looks like your "Family Jewels" are hanging from the frame rails...
