All Crop 40
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: All Crop 40
    Posted: 11 Nov 2016 at 9:10am
Last weekend I brought my all crop 40 home and I've been tinkering with it, I've noticed inside the grain bin there is no shield over the unloading auger. Was there ever one or was it such a small bin it never jammed up?
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:58am
Was never a shield over the auger. Only like an 11 bu. Bin.
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:38pm
Ok thanks wasn't sure, didn't see any bolt hole for one
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 6:44pm
I never understood why you can unload on the go with a 40 but not a 60. The 40 was made in the late 30's, so why didn't they put that capability on the 60s???
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:40pm
Another question for you combine guys, I'm trying to get the cylinder out of this 40 how do you reach the pulley end bolts to hold the cylinder in, you have to be flexible to reach the bolts, any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 6:08am
Maybe that's just it. Brett and I worked together on ours and I don't remember having any problems, other than getting the right wrenches. I don't think that at least one of ours had matching hardware all the way around. Or maybe one of us was on one side with a long extension and the other on the opposite side, both working through the access holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2016 at 1:40pm
i am so tempted when I finally do get it out im gonna tack weld bolts so it will be a one man job from here on in
