alis 180 pto
stevier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevier Quote  Post ReplyReply Direct Link To This Post Topic: alis 180 pto
    Posted: 06 Jul 2012 at 9:57am
My alis 180 has a hydraulic controled pto. It worked but slowed down and stopped completely. Fluid is full. Previously the hydraulic line from the center three lines that enter the front of the oil pan was turning and sheared the line. I replaced the line and prevented the cylinder from turning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 1:53pm
There is a clutch pack in there prolly an o ring or seal broke, , the 2 on the outside are for the brakes ,, may want to do a pressure check
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 2:15pm
Make sure the manual shifter (behind the battery box down where the clutch pedal pivot shaft is) is rotated counterclockwise as far as it can go.....have someone rotate the PTO shaft by hand while you shift it back into gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 3:25pm
Yeah check that first! !!!" That will happen
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 3:35pm
Yes, check the manual bell crank behind the battery box. This got me on my 180. I ended up making a turnbuckle setup to keep it in position.
Apparently the A-C engineers felt that when they went to hydraulic PTO that they could just remove the mechanical linkage and leave the sliding collar and bell crank in place...
Good luck,
CT
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 10:28pm
On my 190XT with hydraulic engage, I put a lever on the shifter lever so I can disengage the pto when hooking up pto's that you can't turn by hand. Now I simply turn pto easily to hook up.
  Hope your shifter lever is only disengaged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevier Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 8:26am
Thanks, first time on forum,you folks were spot on! It was the manual lever.Thanks again!I will be back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 12:47pm
Its nice when its a easy fix! ! Luv them 180,s
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 1:33pm
My fix for the jumping sliding collar lever. I have no desire to rotate it by hand, it is easier to rotate the PTO shaft of the equipment.
Top, pivot point for the manual lever.
Bottom, the collar lever.
Complete view.
This keeps the lever in the locked position at all times. I made the turn buckle setup because it was easier to get the correct tension on it. Not loose, not too tight.
CT
Edited by nsula_country - 11 Jul 2012 at 1:35pm
Outofit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Outofit Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 9:13pm
New to me 180 diesel (and to this site) is having PTO issue.
Seems to go into gear no prob.  When clutch is released out it comes.  Tried to hold into place with no effect.  If PTO not hooked up to anything it will stay in gear.
Did check to make sure bell crank is being moved into position.  There seemed to be a lot of end play in bell crank.
Are all 180's hyd PTO's?
Do not have owners manual but do have a service manual. Not sure if this is something that I can handle if I have to go deeper into housing.
Any and all help would be grateful.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 10:05pm
If it is a single speed, drain PD and rear end then remove three bolts and pull PTO shaft out the back. Splines will be worn on front.
  Linkage on 180 is junk and won't engauge all the way. Then starts jumping out and every time it jumps out it wears the end of PTO shaft.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 12:18am
Maybe a fix like what I did will hold the PTO in. I'm sure my splines have some wear. Since I made this modification, I have not had an issue in over 2 years of heavy PTO use.
CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 3:12am
I had one last year that an ear was broke off on the bellcrank inside, everytime it was engaged under a load it would jump out
