Air filter for W25 power unit
KPaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KPaul Quote  Post ReplyReply Direct Link To This Post Topic: Air filter for W25 power unit
    Posted: 27 Mar 2024 at 11:23am
Hello....looking for an air filter for my W25 power unit....believe the unstyled WF air filter would be the same or very similar...thanks
Grant Forsythe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 7:15pm
I also need one and no the WF air cleaner is not the same. WF and WC are the same. The air cleaner brackets are mounted to the cleaner housing in a different degree or orientation to the outlet. You would have to remove the brackets and mount them to be 90 degree from the outlet on the cleaner housing. That outlet needs to point to the rear of the motor because the cleaner is mounted off the manifold stud in the front of the motor. Also the air cleaner pipe is way different than wc/wf.
The Unstyled Collector
Post Options Post Options   Thanks (0) Thanks(0)   Quote KPaul Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 7:34pm
Okay.....that being said I'd like to find something close...if I had to remove and re-attach brackets that's not really a problem to me...just wanted it to look close...the engine is not going to be a show piece...it's just going to run a line shaft for my edger and planer at the sawmill
This page was generated in 0.199 seconds.
