Air conditioning in '04 Chevy K-1500 pickup
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Topic: Air conditioning in '04 Chevy K-1500 pickup
    Posted: 27 Jun 2020 at 12:16pm
The A/C will work for about 5 minutes, then start blowing hot air.  Haven't taken it to the dealership yet but will soon.  I guess after working beautifully for 16 years and +250,000 miles, I should't complain.  Hopefully, it's a simple fix.  Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 2:18pm
if you have never added a can of R134, i would guess your just a little low on gas... If you have a pressure gauge, you can test it.... If not, look at the compressor clutch and see if it is ENGAGED 75% of the time when setting in the driveway with the AC on...increase engine speed to about 2000 RPM for a couple minutes to simulate what you see on the highway..... with a gauge you should have approx 35-40 psi on the low side and a little over 200 psi on the high side... as the low side dips to 25 psi, the clutch will shut OFF and the pressure will start to climb... about 45 psi it will restart the compressor ... you might see 20 seconds of running and 5-6 seconds OFF while the pressure rebuilds.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 3:08pm
We just went through that with our 02 Trailblazer. They did find a leak in evap line which we knew about but we could recharge once a year and keep cool. They fixed the leak and problem persists. Ultimately turned out to be bad clutch. Gets hot and can't hold. Had to replace whole compressor as clutch comes as a unit.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 6:57pm
Just replaced the condensor on the old gals Chrysler van. 450.00 later it's cold in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 7:17pm
Fixing AC is worth what it costs to me....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2020 at 10:43pm
also check your coolant level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 9:17am
Thanks for the suggestions.  I'll let you know how it turns out.
This page was generated in 0.115 seconds.
