Air Conditioners
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Air Conditioners
    Posted: 25 Aug 2018 at 10:42am
Question? Where does the water go from one of the stand up room air conditioners? Central air and window units have a drain that drips water when in use. What I have read about the stand up units does not mention water drain. Thanks Gary
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 10:51am
We have one in the shop it vaporizes the water into the hot air discharge. it need to be able to exhaust to the outside. we put 2 exhaust hoses together and vented out thru the ceiling  and end wall. that's about the limit longer than that and the water condenses in the hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 9:06pm
Thanks DD. I see that they have a vent included with unit for window.Thanks and have a good day. Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2018 at 9:35pm
it is cheaper and more efficient to use a window unit........... if you have a window, or can cut a hole thru the wall and install.
This page was generated in 0.256 seconds.
