Air Conditioners |
Gary(MO)
Topic: Air ConditionersPosted: 25 Aug 2018 at 10:42am |
Question? Where does the water go from one of the stand up room air conditioners? Central air and window units have a drain that drips water when in use. What I have read about the stand up units does not mention water drain. Thanks Gary
Dakota Dave
Posted: 25 Aug 2018 at 10:51am |
We have one in the shop it vaporizes the water into the hot air discharge. it need to be able to exhaust to the outside. we put 2 exhaust hoses together and vented out thru the ceiling and end wall. that's about the limit longer than that and the water condenses in the hose.
Gary(MO)
Posted: 25 Aug 2018 at 9:06pm |
Thanks DD. I see that they have a vent included with unit for window.Thanks and have a good day. Gary
Joined: 11 Sep 2009 Location: illinois Points: 90793 |
Posted: 25 Aug 2018 at 9:35pm |
it is cheaper and more efficient to use a window unit........... if you have a window, or can cut a hole thru the wall and install.
