Air Conditioner
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: Air Conditioner
    Posted: 27 Jul 2021 at 5:59am
My central air conditioner quit last evening. The whole system, heat & air was new in Oct. '94.  I'm thinking that maybe instead of just fixing the air I should replace the whole system, heat & air. It's an Ultra SX 80.
Dusty
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 6:02am
I would find out first, what the issue is. Summertime is not best time to replace an a/c. You will get bent over a barrel on price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 7:52am
timing may not be perfect, but yes... after 25 years you should do BOTH when you do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 8:22am
'quit'...... could mean a $15 capacitor packed it in, or a $20 relay('contactor'),maybe needs a wee bt of Freon or the fins cleaned ??
Get it checked out FIRSAT before you fork over $10K for a new system.....
My HVAC was put in 1986, still 94+% eff, balls cold air too...... Was going to replace(it's dusty in here(gee, you're sanding wood in the basement...duh....), but it's still running...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 11:22am
It was a simple fix, capacitor, I should have seen that. It's not easy to see inside the area the relays and capacitors are, when it's turned towards the house.
Something that I have not seen before, the repair tech, was a gail.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 11:38am
thats a good fix "for now"...long term it might be time to consider a new unit. Now you have to the time to do it on Your schedule !
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 8:11pm
At the farm outside unit is 1986, inside furnace is 1996. Had to get it filled last summer and this summer so there is a leak. Decided to go with dual fuel heat pump.. Will be changed as soon as it cools off in September. $6000.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 3:41am
LP/Electric? for the backup heat??  Neighbor has a LP backed HP that also has a Electric Coil if decide to turn that on instead of using Gas.  Our ground source has Antifreeze in Ground loops(NO Wells) where we do have a emergency resistance coil, had to use that when the HP lost refrigerant due to a cracked coil while awaited that coil, doubled to almost tripled the electrical bill for those months.  Awaiting a bid from a stove contractor on a wood burner add on supplement heat system.
Edited by DMiller - 28 Jul 2021 at 3:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 5:47am
my guess was a cap...very common they die by drying out(get too hot...),if 'nice' they blow a hole though the side or end to SHOW you, 'hay--I no good'....
I'm happy it was a cheap and fast fix for you !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2021 at 6:07am
Glad it was an inexpensive fix for you. The older units are more durable than the newer ones so do the math; unless you can save money by "upgrading" I would recommend keeping what you have. Women are beginning to start working in the technical service industries; better pay and not stuck in an office or warehouse.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 4:14pm
You need to be aware of the refrigerant yYour existing system is using.  The two systems I just installed in my house, are R410A.  The previous was R22.  Totally different compounds, with totally different operational (pressure/temp) curves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 5:34pm
R22 can use any old AC refrigerant test gauge set, 410A can generate pressures in excess of 400psi requiring special gauge set and all joint fittings are silver soldered.  Was not happy to know that when they changed the Condenser core on our unit.
Edited by DMiller - 30 Jul 2021 at 5:34pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:32pm
Getting a complete new unit put in next Tuesday.   Man said his crew would be here at 9:00 am. Can't wait to get rid of this money eating antique. Outside unit was put in in 1989. It runs all the time, never shuts off and takes forever to lower the temp in the house a couple of degrees. According to him it is made here in the states.
Edited by HD6GTOM - 30 Jul 2021 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:48pm
I bought a GOODMAN air conditioner / gas furnace on e-bay 3 years ago. Installed it myself, then had the local shop come and solder the copper lines together, pull vacuum and check gas pressure ( gas is stored in the OUTSIDE UNIT).... they just pull vacuum on the a-coil and lines........ Worked out great !
GOODMAN is a large USA manufacturer.. They sell to others and resold under several Brand Names..
Edited by steve(ill) - 30 Jul 2021 at 8:49pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 9:25pm
I had a Goodman furnace and AC unit. It worked good but after 17 years furnace was shot, heat exchanger was cracked wide open sending exhaust into the house. Air conditioner was still working but decided to have the whole system replaced at the same time with a Bryant. So far so good.
This page was generated in 0.688 seconds.
