Agco paint cure time
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Agco paint cure time
    Posted: 26 Dec 2018 at 7:34pm
I just finished painting my D19, and I wondered how long until it is cold temperature resistant. It’s in a uninsulated garage that I have a propane furnace in, but I would like to shut it off when I’m not there as soon as the paint is temperature resistant. I used agco paint with thinner and hardener. The spec sheet says full cure in 14 days, but can it go below freezing before that?
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 9:35pm
yes, shouldn't be an issue (IMO)
i use AGCO a lot lately and if you keep it above  freeze for few days to dry it should be fine.
its going to take more then 14 days to full cure though, once you let it get that cold.
i keep any extra paint that i have mixed with the hardener in the freezer to keep it from setting up I've had some paint in there for almost 8 months and it was just as thin as the day it went in.
Dan
Edited by Acdiesel - 26 Dec 2018 at 9:37pm
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf
D12 SER.I, D10 Ser.II
2-720'S
Gmc,caterpillar
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 10:24pm
will be ok; that old hardner dose wanders ;
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 11:37am
with the damp air from the propane heat will add time
