Agco Allis 6670
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Topic: Agco Allis 6670
    Posted: 03 Apr 2024 at 6:26pm
I have a 6670 with air cooled same engine, parked it in the yard 3 days ago, went to move it this evening and it fires right up and runs away!!!! Please someone help or tell me who to talk to, I need this tractor!!!!
Brad Kennedy
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 7:08pm
Does it shut off by cutting off fuel or do you have to kill it with brakes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 7:41pm
Have to kill it with the brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 7:56pm
Sounds like it could be getting oil from somewhere then! Not good. I wish I could help you more specifically.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2024 at 10:20pm
Those tractors use individual, cam driven, pumps. One pump for each cylinder. They have a common rack or rod that ties them together so that each cylinder gets the same amount of fuel. That rod is controlled by the governor. I would check your throttle cable movement to be sure that it is working freely. If that is ok, then you probably have some sort of governor issue. There are a set of weights inside the governor and function similarly to the weights in a gas tractor. Most of us are familiar with what happens when the weights in a gas tractor fly apart.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2024 at 4:21pm
IF memory serves correct - pull the oil filler cap neck and see the 'rack' - you have an injector pump trying to seize. IF you can get the rack freed up by moving it fore aft - run about a gallon of ATF in the fuel and continually rev up and down for a while. The rack turns the delivery valve in each pump - one sticking can cause this. It is a rack and pinion system with the pinion in each pump.
Edited by tbran - 04 Apr 2024 at 4:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2024 at 10:43am
Thanks for all the answers, I’ve torn into it and found 2 pumps froze solid. Now to find some reasonable priced ones🤣🤣
This page was generated in 0.167 seconds.
