advice for Gleaner E in corn
Brian in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian in MI Quote  Post ReplyReply Direct Link To This Post Topic: advice for Gleaner E in corn
    Posted: 16 Nov 2009 at 2:08pm
Will be running the E this weekend in corn and just looking for advice.
Have machine set to spec as per the manual.
Cyl clearance 3/8 inch, speed 500 rpm.
Fan doors wide open, Walkers set back.
Have seen people talking about filler bars,  I'am guessing by the manual
they want it to grind up the cobb instead of it staying whole.
any info is greatly appreciated.
thanks
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 3:43pm
Sounds about right. Just don't forget to get off several times to see what is coming out the back. I had to close the fan some to keep corn from blowing out the back.
It will grind up the cobs pretty good the way it is or at least it did  for me.
9675 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 9675 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 4:10pm
Brian, We've ran a F2 for many years your e will be similar 3/8 is too close you'll grind the cobs. Filler bars help the cylinder to roll the cobs out whole and keep from chunking the cobs. In dry corn we run about 430 on the cylinder speed and 5/8 clearance with 3 concave bars installed. More concave than that and you'll crack a lot of corn. Keep that old girl full and she'll do a fine job! Hope this helps, Steve
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 4:10pm
Try starting at 5/8" cylinder clearance.
Use at least 4 concaves 1 on front rock door, then in the #2, #4 & #5 positions on rear door.
Open the sieve [bottom screen] all the way.
Open the chaffer [top screen] to thickness of your finger.
Open the air all the way.
Run the cylinder near the 550-600 rpm setting.
Ideally, you want to keep the cobs as whole as possible.  Filler bars are used for high moisture corn, 30 percent & higher.  They help keep softer ears/cobs from getting cut up from the spaces between the rasp bars on the cylinder.  Have fun.  They are good machines for corn.  Like Dick L. said, get off and check the rear for shelling action, kernel losses, etc....
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 7:20pm
Thanks for the replies.
Just trying to pick as many brains as possible to get the settings dialed in.
Keep the tips comming no matter how small it may seem.
Thanks  to all,
hoping to have video as well as pics to post back.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 7:34pm
Not supposed to run one on the rock door, check the manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 8:16pm
Jordan,
 My manuals counterdict themselvs.  The manual for the 2E (E240)corn head state to run concave on rock door if rocks may be picked up. This one also shows how to set combine.
The manual for the KL238 (which is the one I'am using) states not to use one the door, but this is also for K,L,F combines.
I plan on using the 1, 3, 5 concave positions. If no rocks are picked up will resort to the 2, 4, 6 positions.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 8:29pm
I run a channel bar on my rock door and have good luck with it.  My K2 is a newer version of the E and I set it similar to the above post.  5/8 for starters on the concave, I shut my finger in the top sieve and shut the bottom one until the sample cleans up.  I have shut it too much and plugged my tailings auger full.  Learning process though, I ran about 800+ bu. through it tonight in just about 2.5 hours.  My tach got wires chewed through so on cyl speed I have been running it about three cranks below full speed, I will slow it down as the corn dries down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2009 at 8:31pm
With my two row head I have picked up stones trying to pick up corn I smudge over with a tire.  I would run a bar on the door just because the concave bars are easier to change than the cylinder bars, and cheaper too.
