Advice for changing fan belt on WD45 |
troy(el paso, il)
Topic: Advice for changing fan belt on WD45Posted: 05 May 2013 at 3:52pm |
Hello All-
Just noticed my fan belt is starting to fray on my WD45, time to change, any pointers would be gladly appreciated.....Thanks in advance. |
Posted: 05 May 2013 at 4:19pm |
Drain the radiator and remove the lower radiator hose at least on one end to get the fan belt to go by it. You have to remove the lower radiator hose...no other way.
ctbowles58
Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
Posted: 05 May 2013 at 5:35pm |
it is a good time to just replace the lower rad hose while you're at it.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 05 May 2013 at 5:51pm |
Don't forget to shut the engine off first!!
Sorry couldn't resist!
Still in use:
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8681 |
Posted: 05 May 2013 at 8:32pm |
Really is easier to get ya a new lower hose and just cut the old one off
Jake9798
Posted: 28 Oct 2016 at 12:54pm |
How do you get it around the bottom pulley? My has a hand crank so there is no opening to slide the belt off..
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 28 Oct 2016 at 2:16pm |
The hand crank rod that goes through the steering gearbox has a spring on it. It should be about 1" away from pulley unless you push on the rod to engage it into the pulley. When you stop pushing the rod flies back to home 1" away.
