Adjusting valves on 7060 - 426 motor
Peter5.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter5.9 Quote  Post ReplyReply Direct Link To This Post Topic: Adjusting valves on 7060 - 426 motor
    Posted: Yesterday at 1:53pm
Going to be adjusting valves on our 7060 with the 426, never done it on these motors before used to big truck motors that have ABC on a pulley to know what is timed to be able to adjust. Please fill me in on everything i need to know!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:33pm
Best to remove valve cover and watch the valves. When it's off see which ex valve is down. Doesn't matter where you are beginning as long as you go through them all in order. Rotate in direction of rotation and watch that ex valve close and it's paired int valve just start to open. STOP! Now find it's "buddy" cylinder and do both valves as it will be up on compression. 1&6 are buddies, 2&5 are buddies and 3&4 are buddies. Firing order 153624. You can go to the trouble of putting timing mark on balancer to find 1 or 6 but not necessary. Just look for the down ex and star there. Chalk mark each when done helps keep track.
Clear as mud?
What big motor has A,B,C? never seen such on my Cats.
Edited by SteveM C/IL - Yesterday at 2:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter5.9 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:56pm
Makes perfect sense will do that way. Our ISM & N14 cummins have ABC on the accessory drive pulleys
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:58pm
Be prepared to do some heavy duty cleaning of dirt and debris from the valve cover to the intercooler area, as it will be nasty. And, as soon as you remove the valve cover this dirt falls right down inside the engine.  Valve clearances are .017" intake and exhaust when COLD.
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:04pm
When you get the valve cover off. get cylinder #1 on compression stroke and turn it to TDC, 0 degrees, then counting from the front of the engine to the rear of the engine, adjust the first, second, fourth, fifth, eighth, and ninth valves. When finished with those turn crankshaft 360 degrees to TDC, 0 degrees and then you can adjust the third, sixth,seventh, tenth, eleventh, and twelve valves.  Its a bit easier to draw it out on a piece a paper, lay it in front of you on the head and you can do it by yourself
