Adding loader joystick to 6080? |
977.3Ford
Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 106 |
Topic: Adding loader joystick to 6080?Posted: 16 Apr 2022 at 9:32pm |
Looking at buying a 6080 with a Koyker loader that is plumbed into the remotes. The tractor will be used for hay work so we need the remotes for rake/tedder, but would like to keep the loader and eventually add a 3rd function to run a hay grapple. Is there a power beyond port to tap into, or some other easy source to use to feed the loader?
Jimmy
1982 8050 Powershift 1982 6080 1992 R52 Gleaner |
MACK
Posted: 16 Apr 2022 at 10:11pm |
Brake the line from remote valves to 3point. Run a line from remote valve stack to a power beyond valve. From loader valve to inlet of 3point valve. MACK
977.3Ford
Posted: 17 Apr 2022 at 9:26am |
Do you know roughly how much hydraulic flow it would have?
Jimmy
Posted: 17 Apr 2022 at 10:57am |
Approx 12 GPM at full throttle.
farmerjohn827
Posted: 22 May 2023 at 10:20am |
i just wondering if you were able to do the power beyond to the loader cuz i also want to free up my remotes in the back of my 6080
ssefick
Joined: 09 Feb 2022 Location: South Carolina Points: 139 |
Posted: 2 hours 49 minutes ago at 9:08am |
I'd like to do this as well.
Thanks in advance! I don't quite understand the return to tank lines. This looks like steps. Buy summit joy stick, and power beyond add on (.https://summit-hydraulics.com/product/monoblock-hydraulic-directional-control-valve-w-joystick-2-spool-11-gpm/?attribute_float-option=None&utm_source=google&utm_medium=paid&utm_campaign=23235872848&utm_content=&utm_term=&ppc_keyword=&gadid=&gad_source=1&gad_campaignid=23235910519&gbraid=0AAAAADOKB2dLkAVQpslB1eLAeBMRQIG22&gclid=CjwKCAiAqprNBhB6EiwAMe3yhpzdznrDVNiZwan1RU48xkAX5qjslXzQ5nA2D95BAEMgiT4EICWzXhoCS4UQAvD_BwE). Break tank line. Go to joystick Power beyond to 3 point hitch. Hook up tanks lines? |
