Adding Hydraulic Ports to AC 6060
Tractor_Rookie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor_Rookie Quote  Post ReplyReply Direct Link To This Post Topic: Adding Hydraulic Ports to AC 6060
    Posted: 09 Mar 2017 at 8:36am
Hello all, I have an AC 6060 and I am wanting to add a loader that I have found an actual AC loader for the 6060, however I only have 2 hydraulic ports in the back of my tractor, how can I add 2 more so this loader will work correctly. Is there a 2 to 4 port conversion or do I add 2 more lines? if so how. any assistance will be great thank you.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 11:59am
Someone offered a hydraulic outlet multipler at one time. Sad part is I can picture the add but can't think of the brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 12:20pm
Your best solution is to buy an open-center "joystick" hydraulic valve, set-up for power beyond. Then, the loader has a valve of its own and the outlets on the tractor are available for other things.
