Adding a pre flush to trans/steering system.
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Adding a pre flush to trans/steering system.
    Posted: 30 Dec 2017 at 2:43pm
Hello friends.
I Will be draining my transmission/ steering fluid for a changeover. Would a pre drain flush additive like Sea Foam Hy Tran flush help clean the system and valves prior to dumping fluid or is it a waste of money. I have a HD16DC. Not sure when a complete fluid change was done if ever. Thank you
Morten.have View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morten.have Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 4:59pm
I’ve have flushed my system. With diesel fuel and run the pump and clutch several times, then drain it all out and change filters and add new oil. I flushed the trans system because of several years of still standing, and therefore condensation and dirt.
I will not recommend you to be a “can” mechanic and add all sorts of addictive in good oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 5:42pm
So long as machine is well warmed, the oil is allowed to drain fully and fresh fluid/filters installed should be no need for additive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 5:56pm
Hahaha spoken like a real mechanic to a filters and fluids kind of guy.
Thanks Morten, and I agree with ya. I'm not an otc additive kind of guy. Tractor sat a very long time with little or no maintenance done. Just thought system could use a good cleaning followed by Fresh fluid and filters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 5:57pm
Thank you. Makes sense.
This page was generated in 0.152 seconds.
