Add on D15 Hrdrolics?
Brian(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Topic: Add on D15 Hrdrolics?
    Posted: 16 Dec 2011 at 12:46pm
Looked at a D15 II that didn't have rear couplings, how hard would it be to add a set.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 5:10pm
THERE should be a pipe on the rear if it was neaver used it will have a pipe cap onit just remove the cap and screw on hyd. fitting it would be 1/2 in. pipe thred
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2011 at 6:25pm
You looking for single acting or double acting hydraulics on the rear? The D15 came with single acting hydraulics and CT told you how to get a single acting rear remote (altho you will probably have to wait until the rear lify arms raise before you get pressure in the rear remote. Plumbing, fittings, and valves are needed if you are looking for two rear remotes.
