adapting wheels for your puller |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Topic: adapting wheels for your pullerPosted: 07 Jul 2016 at 8:08am |
I am not familiar with that name but my family only moved to the area in '92 and Abilene is our town rival so I never really associated with them much.
I have the iron for wheelie bars and front bracket, friend and I are going to throw them together tonight. going to wait on the hitch as im still looking at examples and very short on time..... nothing like last minute
180Puller
Silver Level Access
Posted: 06 Jul 2016 at 10:28pm |
Looks good...Cant wait to see the UC on the track...Its been a long time since I've seen one pull...Did you know the late Wayne Whitely at Abilene?
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 06 Jul 2016 at 6:04pm |
What junk? It all looks like a functional shop!
dawntreader74
Posted: 05 Jul 2016 at 11:23pm |
good luck at the pull''
CAL(KS)
Posted: 05 Jul 2016 at 7:55am |
will do. Hope to make inaugural pull this weekend. I will post some pics
dawntreader74
Posted: 04 Jul 2016 at 9:36pm |
i would keep a eye on them for cracks' you did a nice job' but welding on them takes the temper out of the rims ' some times it will bust out next to the weld.
Amos
Posted: 04 Jul 2016 at 7:41pm |
Good work!
mjbower
Posted: 11 Jun 2016 at 7:03am |
Yes please keep pictures coming always wanted to Build a UC to pull
CAL(KS)
Posted: 09 Jun 2016 at 1:20pm |
I am creating this post to document my process of adapting wheels to my tractor. Some people use adapters, I chose to weld in a new center because its lighter and I like the looks better. Right or wrong, I am commited now.
Here is a picture of the wheels and tires as advertised. I decided on 16.9x34 because they offer the largest foot print in the classes i will be pulling in and should work well with my gearing and rpm. and of course the old hard and sharp tread. ![]() The 9 bolt pattern wont work on my tractor and the centers are set too deep so a cutting we go. Here is the first step with the tires removed and the center out. boy were those tires on there!! ![]() With the center out i can cut out the 9 holes and insert my custom 6 hole center disk. I had 6 hole center made by my machinist friend and the 9 holes removed at a machine shop so it would be centered and clean. friends machine didnt have a big enough throat/ swing ![]() Center disk tacked in. ![]() Checking trueness? and depth of rim on tractor. UC's have a reputation for being very wide so im going as narrow as possible. about two inches clearence between tire and brake housing. I have measured the width at the wheels with tires fully mounted at 92 inches. my brothers wc is 89 inches so not to shabby i thought. ![]() Before the wheel center goes back on the rim i have to repair the holes cut where the center was removed. ![]() ![]() Since I was cleaning the final drive up and installing new seals, i laid it over and mounted the center then installed the rim to final depth and spun it checking to see how true it was before i made it solid. apparently i didnt get a pic mounted. ![]() In my haste to get them done, i didnt snap a picture of welding the centers to the rim. Picture after sandblasting and painting black. ![]() Pictures on the tractor to come very soon i hope. I have the rims on and tires mounted but would like to get tractor outside for a good picture. Will share more tractor details then. ![]() ok i found this picture i had of the tires and rims mounted but im a little embarrassed by all the junk laying around lol. still a work in progress. all the bolts and alignment dowel are not it, i still had to pull the left final at this time. ![]() Edited by CAL(KS) - 09 Jun 2016 at 1:57pm |
