AD40 Grader
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: AD40 Grader
    Posted: 06 Sep 2018 at 1:58pm
if it's a 40,it came out with a 4-71 Detroit. A 30 used the 3-71
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2018 at 6:37pm
It's a AD4 looks just like mine
160 CA 920diesel 5020 HD-3
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 11:57pm
Originally posted by ac fleet ac fleet wrote:
I had a 1960 45 with 6 cyl.  allis engine and jimmy supercharger. thanks ; ac fleet
The engine with supercharger was Lanova injection and might have just continued from what Buda was making when Allis bought them.
If you're being a purist - with that engine  it is a "Forty Five" (i.e. spelled) and the later ones with 10000 series engines are "45's (numeric).  But most will get the idea with "45".
A 1960 one might have been close to where they swapped to 10000 series engines?
The supercharger might look like a GM but it is cast iron and made by Sweitzer - and heavy
Edited by Ian Beale - 31 Aug 2018 at 12:04am
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 8:35pm
fishnhuntr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fishnhuntr Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 7:39pm
Tag on left side of cab
   Model AD-40
   Serial number. 4070
   One other tag has
   AD-40. 24 7
Found out it is 1950's
Weigh about 18000#
Appears to be 3-71 GM diesel. Power steering. Gear drive controls no hydraulic cylinders
Any of this help to identify this ole girl??
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 7:11pm
Ring gear on wrong side of pinion gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 6:33pm
Hi Dave
I thought Allis was out of Detroits around 1954?  Or did they start using Budas?
Next question -  did the "Forty Five" come out 55 - 56 era then?
If that book has serial numbers try 524 - 204 for a serial number.
The "gotcha" is that is an Australian production number  which makes reading a US parts book an interesting chore.  By the "It has this but it doesn't have that" system I've got ours to within a couple of hundred.
The Australian ones had Hydreco hydraulic pumps - must have been a licensee building them here I guess.
This also turned up in the search - 6 reverse, 2 forward gears
Edited by Ian Beale - 30 Aug 2018 at 6:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 6:15pm
Originally posted by Ian Beale Ian Beale wrote:
DIY Dave
23000 lbs and 1957 sounds like an AC Forty Five.
I found this
Sell Allis Chalmer AD-40 Road Grader By Kennedy Equipment, USA
1953 AC Grader AD-40 Road Grader Detroit Diesel Engine, 12 foot Moldboard with good edge, 13:00 x 24 Tires, Runs & Operates good. PRICE REDUCED
Search domain www.tradekey.comtradekey.com/selloffer_view/id/52769.htm
Per Swinfords book, I got the year wrong, they only made  AD40"s from '52-'55.  Weight is right, 23.000 lbs...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 5:08am
DIY Dave
I found this
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 4:50am
23k lbs, and most likely 1957.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fishnhuntr Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 12:21am
Just purchased a AD40 grader.Serial number 4070. Diesel 3 speed with hi low box 13:00x24 tires.
   Can anyone tell me the year and weight. Was told it was a 1970's by seller.
    Thanks from Montana way.
