Acetylene torch questions
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Acetylene torch questions
    Posted: 29 Oct 2023 at 7:16pm
I recently bought a very nice like new Victor acetylene torch.
It’s the smaller one (100) I believe?
It’s missing the torch handle but has everything else.
Cutting head, rosebud, 3 welding tips hoses and gauges .
Mt question is this, do I need back flow protectors or flash back arrestees and what’s the difference?
Also looking for a torch handle to go with it.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 7:33pm
Yes, you need the flashback arrestors. They protect YOU and are a worthy investment/requirement.
You are after what will be referred to as the "mixer". The Victor and Harris/Calorific designs have been copied for years, but the used originals can be had on Ebay and are worth rebuilding being supported well.
I have original "Smith" torches and gauges and they are prized possessions.
That's All Folks!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 8:11pm
i have realy no need for flashback pre venters but i do have quiki quick disconectes on all of the torches and on allthe regulators  we use oxygen disconct on the argon, helium, nitrigen, gold gas, oxygen,  and acyetlene disconect on the acetelene, and propane , i do alott of cutting with propane
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 8:20pm
  Hey Ole Buddy,,,I think I may have the handle you looking for,,,I'll check in the morning as it is down to 31° here and light snow,,,,can't figure how I got on ole Shameless's CHIT list,,,,,?LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 9:06pm
flash back arrestors are just that... they prevent flash back if something goes wrong... And they dont cost but a few dollars, so why not use them ?  ........... also, they are required by OSHA for all Businesses.
Kind of like seat belts... You dont need them 99% of the time, but when you run into a brick wall, you wish you had it on !! Wink
Edited by steve(ill) - 29 Oct 2023 at 9:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 7:24am
Many of the newer torch mixer heads already incorporate Back Flow preventers, my replacement torch to my antique Union Carbide set I could no longer get regulator parts for is built that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 9:32am
I also have a large Smith set. The gauges have nice steel covers for use on a welding truck.
The oxy gauge needs rebuilt.
This smaller set will be nice for everyday use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2023 at 9:43am
I'll look at the shop for the contact information of a gent I use to rebuild regulators. He is inexpensive yet very good if parts can be sourced.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 5:24am
Are back flow protectors and flash back arrestees the same thing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 9:26am
Yes they are in the application.
That's All Folks!
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 9:58am
Well Thad.  I was fixing to get my tanks and equipment out to start torching an old truck box that was used for feed storage.  Now you've got me thinking I'm going to blow up.  Definitely going to check and see if I have arrestors on the new torches/regulators i bought!
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 10:15am
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2023 at 1:54pm
If you bought them new in the last few years you probably have built in
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 8:09pm
I have both the Victor medium mixing chanber and the large one with cutting head only , I have been using propane as fuel for cutting for last 25 years and just accetylene for brazing work . Did buy a rosebut for the propane as the one for acceteline poped and flashed when run with propane . Was thinking of going to MAPP Gas as around here most places will not fill accetilene tanks now
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2023 at 9:13pm
The arrestors or backflow are for when an awe happens, if the line gets severed or burn, stop the flame from getting to the tank. Really a good thing to have. HTH Tracy
This page was generated in 0.174 seconds.
