AC720 oils?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Topic: AC720 oils?
    Posted: 30 Apr 2021 at 7:52am
I have enjoyed my 'new to me' AC720; need to change oils. What do I use:
air cooled Onan engine?
hydrostat?
dropped rear axle?
hydraulic lift?
Herb(GA)
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2021 at 5:29pm
-I use sae30wt in my Onan CCKB with a Purolator L20195 filter.
-I use cheap Rural King brand Dex/Merc (by the gallon jug) in the hydrostat with a Napa/WIX 51085 filter, but you could use Type F transmission fluid as well.
-I use straight 90wt gear oil in the drop boxes.
The hydrostat, lift system, and transmission all share the same oil.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 6:51pm
Bird76Mojo,  Thank You.  Herb(GA)
