AC720 electric fuel pump? |
Herb(GA)
Joined: 15 Sep 2009 Location: United States Points: 1039 |
Topic: AC720 electric fuel pump?Posted: 25 Mar 2021 at 9:14am |
NAPA employee search came up with Facet 40131N fuel pump 9452 for ~$140 from ebay. Printing on they original pump label has faded; appears to be PRMR(?). Would appreciate knowing what others have experienced. Herb(GA)
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2591 |
Posted: 25 Mar 2021 at 10:51am |
I've used a
Mr Gasket 2-3.5 PSI Electric Gas Fuel Pump 42S - AutoZonehave two 720 and these work great on them. Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11385 |
Posted: 25 Mar 2021 at 3:12pm |
I used on I bought off the internet as long as you leave the return line on so you don't put too much pressure on the carb any electric should work
mnoonan-NEWI
Joined: 11 Sep 2009 Location: Marinette, WI Points: 739 |
Posted: 25 Mar 2021 at 7:05pm |
I use a Facet model 40104 electric fuel pump kit on my 720's. You can buy online or at NAPA. It's a low pressure, I think it is 1.5 to 4psi. I usually remove the original mechanical fuel pump and cap it off. I also still use the return line.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 26 Mar 2021 at 6:19am |
We offer a complete fuel pump kit if interested Herb. Visit our website. Our P/N 1703-22. Comes with mounting plate, fuel pump, relay, oil pressure sender, wiring and instructions.
Steve@B&B
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 26 Mar 2021 at 9:34am |
I think it was the spring of '14 we bought an A.C. 720 that had a replacement engine, the original engine was included, it's still in the cardboard. I don't see where I'll ever need it, so if anyone needs it, let me know.
Dusty
Herb(GA)
Posted: 26 Mar 2021 at 11:52am |
Steve, I like your design of including an oil pressure sensor in the circuitry. Dusty, thanks for your offer. My 720 has been treated well and does not get much use so I do not expect many problems; mqy be some one else has a need for your used Onan engine. Herb(GA)
