AC-7040 - No throttle response |
dualquads
Topic: AC-7040 - No throttle responsePosted: 06 Nov 2025 at 8:24am |
Needing some advice.. Think I may have an injection pump problem? Tractor will start and idle at ~1000 rpm. Constant or extremely slow throttle, might get 1300 rpm sometimes. Engine sounds normal firing all 6 but no power, lifting the wings on a bat-wing mower will lug or stop the engine. I have replaced the fuel filter, rebuilt the primer and blown out the fuel line back to the tank. The throttle moves the pump linkage fore and aft to the stops on the pump. Tractor sat in shed without being started for almost 5 months this spring/summer due to my medical issues, was running fine before. Thank you for any insight!
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5140 |
Posted: 06 Nov 2025 at 8:35am |
Metering valve in pump is probably sticking. Take top cover off and timing window off side to drain fuel down, and spray brakleen around the metering valve. If it's sticking, it will not respond to any loads. It may be due for proper servicing if it's really nasty inside. When they get gummed up, they can have the transfer pump regulating piston also stick, causing the pressure to spike and it results in a seized head and rotor assembly. Then becomes a very expensive repair lol!
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10110 |
Posted: 06 Nov 2025 at 9:35pm |
Not saying this will work in your injector pump but I dumped some ATF into my John Deere 4050 fuel tank. This seemed to help free things up. Tractor runs perfectly again.
Worked well with my 1983 F-250 with 6.9 diesel.
GM Guy
Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1988 |
Posted: 01 Dec 2025 at 2:47pm |
like Ed said, sticking metering valve.
It seems the 7K series is extremely prone to this because of the belly mounted fuel tanks with large exposed surface area causing wild expansion and contraction due to temps. it seems the heavy "breathing" is more prone to pulling in condensation and therefore water in fuel, and that causes rust and corrosion. I generally keep my 7K series full of fuel with a good lubrication boosting additive like Stanadyne Lubricity formula. Whenever I have one stick I blow out the upper housing and refill with that additive, then get my fingernail down there to gently work the tab on the valve, usually you can feel it break through a varnish layer then work freely if it hasnt been sitting long. Edited by GM Guy - 01 Dec 2025 at 2:49pm |
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Posted: 01 Dec 2025 at 3:01pm |
I believe that was one reason they eventually went to the plastic tanks. Less sweating.
