AC7020 Filters
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Topic: AC7020 Filters
    Posted: 17 May 2023 at 2:29pm
I am changing all the fluids in my new to me '78 7020.
The bypass oil filter is 74061714 and AGCO wants 270$ !!!
The local filter specialists would sell one for 60$ except they can't
find one by Baldwin or Fleetguard.They claim the filter is obsolete.
Does anyone know of a filter brand that might be in stock?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 3:12pm
AGCO new part # is 74057969 for 158.50
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 4:49pm
We take them off and plug the lines at the block. If customer insists we find one off an 8070 i.e. and use the 74036791 filter and used orfice to restrict flow.  The OEM bypass is so messy to change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 5:14pm
I also did a cross ref check - Agco is cheaper than any I found - if someone finds one please post - All variants are $100 plus...
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 6:03pm
270 is in Canada and is in canadian dollars.
Sounds like blocking off the lines is a decent solution.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 6:20pm
Whenever we eliminated one of those, we always told the customer to change the oil every 100 hrs instead of 150 hrs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 6:31pm
I can change oil at 100 hours.
Thanks everyone for the advice!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 9:07pm
Take it off. They have ruined  more engines than they have saved. Blow top gasket out and you have lost a engine.                  MACK
This page was generated in 0.039 seconds.
