AC5015 not charging
Chester330 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chester330 Quote  Post ReplyReply Direct Link To This Post Topic: AC5015 not charging
    Posted: 21 Oct 2025 at 6:01pm
what is the  best way to test the alternator and regulator on AC5015
I checked the voltage today running at fast idle was only  at 12.73 volts at the battery
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 8:15pm
i think the 5015 has an alternator with an internal voltage regulator.. Not sure there are parts available for rebuild... Might be cheaper to just install a new aftermarket alternator like a DENSO Mini, etc..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 54 minutes ago at 7:19pm
Take it off and bring it to a local rebuilder to run and load test it. He'll be able to tell you how good it is or how bad.  They can be rebuilt, but sometimes it's better to price out a new unit first as Steve mentioned. The little pint size Denso fits a lot of applications with little mods.
Steve@B&B
