AC200 ran fuel dry; help with bleeding? |
rickannable ![]() Bronze Level ![]() Joined: 12 Sep 2014 Location: Chesterton Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jun 2020 at 5:33pm |
Hello guys,
Dad ran the tractor dry of fuel and we are having trouble getting it to start. We've got fuel through the water separator and the filter, so I figure it's at least to the pump. I know once it's running we can crack the fuel lines at the injectors to bleed the air, but right now we have no fuel up there yet. Does anyone have a really good description of how to get the old girl started again? Much appreciated! Thank you. |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
You need to crack the line at the injectors before you start cranking. Watch for fuel and then tighter. Once it starts bleed each injector till it runs smoothly.
Pump primer and crank. I never bleed inj. lines if primer pump is good. MACK
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Loosen bolt on pump housing its right on the front facing you- takes a 1\2 inch wrench- get fuel there then go to your injectors
