ac wheel weights
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Topic: ac wheel weights
    Posted: 29 Jan 2011 at 7:51pm
did allis ever make 1200lbs wheel weights i was told the pair i just bought came off of a d-21 1200lbs a piece and they fit on the inside of the wheel?  Thanks
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2011 at 10:12pm
The weights are Tyler weights made in Tyler Texas I've been told. I think that the inside ones are closer to 1500 lbs each and the out side ones are a little over 1100 lbs each.
I have a set on the way from PA and plan on using the inside ones on my 220. I'm installing Mexician hat duals so can't use the soutside weights. This set came from Kansas on a D-21.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 9:50am
I saw a set of them on a JD 6030 yesterday that had the 25.5/32s at a sale, the same ones that you are talking about I am dure, I have seen a few 21s with them, and a few sets here and there
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 11:47am
thanks for the info guys after looking at these weights i noticed the 7040 picture on this sights main page also has the same weights on it. kinda debating weather putting them on the 200 or 7080
