AC Weights and part numbers |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Dec 2014 at 6:07pm |
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3860 |
Wow didn't know there was so many look-alike weights for WD & then to fit B's I'll have to go check my pile of weights to see if they are all the same numbers or if I might have some for B's Thanks for posting this Charlie !!
orange ![]() Bronze Level ![]() ![]() Joined: 09 Apr 2011 Location: watertown s d Points: 140 |
Have a weight with a # 406282 on it fits on a wd Oxnard ?
thanks Terry |
alliskid13 ![]() Bronze Level ![]() ![]() Joined: 18 Mar 2015 Location: Missouri Points: 15 |
Had no idea there were so many kinds of weights. I have a pair on my WD45 off of the A and B Deere's
Holmes ![]() Silver Level ![]() Joined: 13 Dec 2009 Points: 56 |
Is there some place that has the # for weights? Will I find it in the parts books. Trying to get things all written down in one place.
Click on the live link in the original post!
Thank you for all the help on numbers on AC weights. You guys are great.
mcm ![]() Bronze Level ![]() Joined: 28 Jun 2014 Location: Iowa Points: 12 |
Engine weight question?
I have a 1948 B. Today I purchased a pair of engine weights at a farm auction that I believe to fit a B or C. Do I need a sleeve around the bolt in 2 of the holes? and Does a bevel indicate an older weight??? and does the bevel go up or down? Thanks, MCM
I believe the bevel was clearance for the B steering arm, so it would go on the bottom on the left side.
I don't think you can turn the weight upside down and still bolt it on???? Edited by CTuckerNWIL - 03 May 2015 at 4:50pm |
Thanks, that makes sense. None of the AC experts at the auction could help, never having seen a set before. I've not had a chance to jockey them into position yet. Had my workout for the day just carrying them to the truck. MCM
JM ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: United States Points: 379 |
Will WD wts fit the styled WC centers? I did not see any listed for the WC.
Roger Nolin ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: Monroe Iowa Points: 189 |
yes, they should. I have a pair of F&H weights on my WD and another set on my 42 WC cast center
Jason(OH) ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Jeromesville, O Points: 188 |
Will the WD/WD45 front donut weight fit on the inside of the rim? Is the center hole large enough to go over the wheel hub?
Dana(Iowa) ![]() Bronze Level ![]() ![]() Joined: 22 Aug 2010 Location: Central Iowa Points: 52 |
I have a set of engine weights on my C. A bolt is used on the front (If I recall correctly, it threads into the front plate and the weight slides over it) and a bolt goes into the side of the bell-housing which effectively locks the weight onto the engine.
1957 D-14 with loader
1947 Model C (restored) 1947 Model C (unrestored) SOLD! 1972 220 |
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
The correct front B/C side weight front mount is a bolt with a bushing that fits the hole in the weight. A stack of about 10 Metric flat washers with a 3/8 hole makes a good bushing. OD is near perfect
Edited by Ken in Texas - 11 Aug 2018 at 10:08pm |
housemover ![]() Bronze Level ![]() ![]() Joined: 01 May 2012 Location: Belleville, Ks Points: 103 |
Does anyone know why the change in pie weights from D-17 I &II to D-17 III & IV etc. I'm starting to wonder if it was function or cosmetic!! And has anyone ever Tried to stack the pie weights like the older WD weights' Also many, many early D-17's used the flat WD weights in the Midwest in my childhood. Thanks " Housemover"
dozerdan ![]() Bronze Level ![]() ![]() Joined: 03 Aug 2018 Location: portland or Points: 11 |
Does any one know the aprox weight of a AC Mod M crawler motor ? Getting one shipped from NY to Oregon need shipping weight ...
Hunt4Allis ![]() Orange Level ![]() Joined: 13 Mar 2018 Location: Ohio Points: 1160 |
Great job on this slowely becoming lost information, thanks fellas
Sunburn ![]() Bronze Level ![]() ![]() Joined: 12 Feb 2019 Location: Georgia Points: 13 |
Greetings! I'm new to this forum. My dad bought a WD in 1954 and I pretty much grew up riding that tractor. Never got over the fond memories associated with that tractor. I have a set of rear weights off a WD in my barn. Does anyone know the best way to sell them and approximately what they are worth?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 52933 |
Put them on the classifieds here, or on CL, and provide a link. as to value, here in md, about $150 a set...
THANK YOU!
Wow! Thanks! The ones I have look like the ones for a WD45. Part #AM2795-10
Thanks again 1 |
RPCV93 ![]() Bronze Level ![]() ![]() Joined: 03 Jun 2022 Location: Belleville, Ill Points: 1 |
good pictures and info, thanks
1963 D15 series II - restored
1966 D15 series II - original 1974 185 Crop Hustler 2008 B7800 Kubota 2008 T1670 Kubota 2019 G2120 Kubota |
ChrisS ![]() Bronze Level ![]() Joined: 10 Mar 2016 Location: St Marks, KS Points: 63 |
I see in the link there are sectional weights shown for a D19/190 with the casting # AM 5052-2. I found some (12ea) sectional weights that look identical but have the casting # AM 5052-3. I have a few questions.
1. What the difference between a -2 and -3? 2. What do they weigh? 3. How many does it take to go around the rim? 4. What are they worth? Thanx, Chris
Kip-Utah ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Southern Utah Points: 875 |
It’s been a LONG time since I put the engine weights on my C and another set on Dad’s B. But I remember using a carriage bolt & a short piece of 1/2” pipe for the bushing on the front mounts. Kip
Simon2 ![]() Bronze Level ![]() ![]() Joined: 22 Nov 2022 Location: Wisconsin Points: 21 |
Anyone making repo D series front mounting bracket for the flat type stack weights?
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 2951 |
DJ's tractor parts has the D series mounting brackets and J hooks. I bouhgt a set last year. They were good quality.
