AC - WD45 OIl pressure |
Stanley
Topic: AC - WD45 OIl pressurePosted: 09 Nov 2010 at 8:26pm |
I have a WD45 that starts w/ decent oil pressure and after it "warns up" the pressure drops below the "N" on the gauge.
What is the recommended oil type/weight and filter for this tractor. Also I've read on this site that the tube/pipe in the oil filter needs to be a certain length. I have added a washer to the oil pressure relief valve and there is little if any improvement. Any suggestions will be appreciated. |
Brian Jasper co. Ia
Posted: 09 Nov 2010 at 9:10pm |
Good oil pressure cold that goes away warm usually means worn bearings. Time for an overhaul...
Stanley
Posted: 09 Nov 2010 at 9:49pm |
I was afraid of that.
MACK
Posted: 09 Nov 2010 at 9:50pm |
As long as it is in the normal range it is ok. MACK
wjohn
Posted: 09 Nov 2010 at 10:30pm |
My father's WD has the same problem as your 45, except Dad refuses to believe it's a problem. It still runs which to him means it must be fine. Can't say I didn't warn him!
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 10 Nov 2010 at 3:05am |
Oil pressure will drop some as the engine warms up. It is normal. As long as it doesn't drop too low you will be fine.
KC-WD45
Joined: 11 Oct 2010 Location: Kansas City Points: 114 |
Posted: 10 Nov 2010 at 9:53am |
What you might think of as low might actually be normal. According to the manual 12 pounds is normal. After I rebuilt mine I was expecting to see quite a bit more than that since 12 is about at the bottom of the gauge but I was relieved to find out that 12 is what it was supposed to be. You might hook a gauge up to it and see how many pounds you have before you tear it down. Could save you a few bucks!
KY
Posted: 10 Nov 2010 at 2:22pm |
Use 15-40 and a quart of lucas. Make sure tube is not stoped up or pushed down too far.
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 10 Nov 2010 at 3:28pm |
try straight weight motor oil start with 30 go to 50 weight
KY
Posted: 10 Nov 2010 at 3:40pm |
That works too, any thicker oil. The lucas really made a difference in one for me.
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 10 Nov 2010 at 4:18pm |
Stanley - I would check the guage. My 45 was showing "N" on the guage and when hot on a 95 degree day,the guage hardly registered. I replaced the guage with a 15# guage and have had no problems since. Cold is about 13# and on a 95 degree day its about 9-10#. - AL
pineyjd
Joined: 12 Sep 2009 Location: Southern NJ Points: 100 |
Posted: 11 Nov 2010 at 3:17am |
My I40 showed low pressure,took tube to gauge off & cleaned,now shows 20-25,was showing 5
Stanley
Posted: 11 Nov 2010 at 6:41pm |
Thanks for all your help.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 11 Nov 2010 at 8:29pm |
Stanley take a look at this info Jim from OK Tractor posted three years or so back about oil filters. Don
Stanley
Posted: 12 Nov 2010 at 10:18am |
Good information Don, Thanks. Where can I find an "old Style" filter? Any suggestions?
KY
Posted: 12 Nov 2010 at 12:34pm |
Yes your agco dealer will have them. Baldwin filter co. Also makes em.
Brian Jasper co. Ia
Posted: 12 Nov 2010 at 3:33pm |
Those "new" style filters should be out of the parts system by now. That's been more than a few years back if I remember correctly. I've been told that if the oil pressure gauge moves at all, they will live.
bluebanshee
Posted: 12 Nov 2010 at 4:22pm |
I think Baldwin makes filters for Hastings so they should be the same. I have a hasting one and it is the correct type of filter. Last time I bought a filter it was cheaper at TSC than advance.
