AC vs Farmall
Message Reverse Sort Order
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Topic: AC vs Farmall
    Posted: 20 Nov 2023 at 1:54pm
I always thought AC had the best engineering of their time (right up through to the 7000/8000 series), but fell down a little when it came to build durability. I love My Allis's, and would rather drive on a WD than an M (or especially my W6, where you sit as if you're about to give birth). But I have to begrudgingly acknowledge that if any of my Allis's were treated like my IH or Fords, they'd have cracked their front axles, be jumping gears, and generally beat to heck.
Don't judge me for saying that: I still love my Allis's more than other makes (though the Fordson Major and Ford 5000 might be up there with the Allis's). But knowing what I do now, if I were buying a new tractor in 1955 it would depend on the type of use I was putting it to. If I were using it primarily haying or doing other lighter field work on flat land, I would go with the Allis without hesitation: Far more pleasurable to drive and well thought out. But for beating about in the bush running log winches/wagons and smashing over the stony fields up in the Canadian shield at our Northern farm, I'd have to begrudgingly take the IH.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 11:54am
Some seem to be misinterpreting.  I'm well aware that the CA was slightly newer than the H and M (although they overlapped some).  But my criticisms extend to the follow-on Farmalls that some say are more comparable.  I was not comparing feature by feature.  I'm talking about things like the sleekness of the castings (evident in older ACs to some extent as well), how well they flow into each separate section (Farmalls seem more like tinker toys and blocks the way they join), the routing of cabling and controls, the design and positioning of the controls, the simplicity and ease of use.  I see little improvement in the IH "super" series tractors in these areas.  I do see improvements (catching up) in a decade or so later (60s) versions.
Also, with regard to wheel diameter.  You'll note that I did say "partially" compensate with tire width and weight (and tire pressure and other things).   Of course, you can also make these adjustments to the larger diameter tire.  But you can increase the competitiveness of a smaller diameter tire relative to a specific larger diameter tire with width and weight, and significantly so.  I'll also note that the increase in tire size/diameter also reduces the effective horsepower/torque available at the ground without gearing changes.  Even the increase in wheel weight can have an impact to reduce horsepower/torque.  As little as 1 inch in diameter increase can have a significant reduction impact.  So...there are a lot of factors to consider.
I also don't think you necessarily want to build maximum bulk into the tractor frame.  You want a lighter tractor for some operations (e.g. cultivating) and a heavier tractor for other operations.  The ability to add and remove external weights is the best solution to right sizing a tractor to task.
Edit:  I do think the routing of the CA (B/C) steering arm is substandard/antiquated.  I've never liked that arrangement.  I would probably have also designed the CA to more easily add a reinforcement frame similar to the IB frame (but less kludgy).
Edited by dfwallis - 20 Nov 2023 at 12:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 11:35am
Originally posted by jvin248 jvin248 wrote:
Both IH and AC were trying hard to skirt around Ferguson patents for the three point hitch and top link draft system. Both were compromises.
Which one won out? Ferguson. It's on everything modern. Sure there is a quick attach from skid steers put on them.
While we had a WD it was mostly relegated to sickle bar mowing and the chopper and round baler that was used until the novelty wore off.
The Ferguson we had did everything. We had Oliver and IH six cylinder for heavier work. Refurbished, the Ferguson is my current workhorse. My WD is for fun. My Seventeen year old doesn't like driving the WD.
I think all the tractors were fairly crude until the 1960s. After that all the equipment became a bankers game of financing equipment, land, and inputs driving out most small family farms.
Just because the Ferguson design won out doesnt mean it's a great system.  I prefer the snap coupler design, but I'm sure we could design something better than either.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 7:30am
My big gripe against any of the W series is the afterthought of an operator's "platform". I don't like sitting off to one side with my right knee getting whacked by the hand clutch and my left leg needing to be 6" longer than the right leg to reach the clutch. If they would've placed the operator in the middle with an actual platform like a Farmall, I think they would have a much better tractor. This is the only reason I don't own a WD45. Aside from that, I think they are outstanding machines.
Creston, a flip-over seat bracket goes a long way toward solving some of your W problem.
The traction booster flat out works! Maybe a year from now I'll have an experienced opinion of the early IH draft control system. Maybe the later style, think 56 series too. I did plow a couple acres of sod with my 756 once. I was having so much trouble that day I can't remember how draft control worked. That Oliver plow hooked on the 185 worked great.
I will say this, I go to a lot of plow days and the Red tractors/plows that go, they work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2023 at 7:23am
Originally posted by dfwallis dfwallis wrote:
I did some minor work to a Farmall H and an M while working on my CA this spring and fall.  I kept getting the feeling that I was working on something antiquated and poorly engineered, kind of model T-ish and after-thought-ish with the H and the M.  Not that the CA is all roses (clear structural weaknesses), but it does seem like a little more thought went into it.  Thoughts?
  It seems as this post is comparing apples to bongo drums, With the 2 different tractors being designed in totally different eras. In the late 30s the Allis Chalmers WC & UC tractors are more of a comparison to the first (1939) of Farmall's H & M Tractors. Even so,  Allis Chalmers had the idea of "high-Speed" farming whereas Farmall was just a modernized version (for the time) of brute force to get the job done. This basic design was carried into the 350/450 tractors with running improvements. Even the design of the 460/560 in 1958 was only a somewhat minor design change for Farmall.  The Allis WD came out in 1948 and the CA was introduced in 1950, these 2 tractors had many firsts that had never been seen on a farm tractor.
  At this point in time most all of the implements used were primarily drag or trailer type, with the main exception of row crop cultivators. Anyone that has used both the H&M cultivators along with the WC cultivators would agree you could install/remove the Allis Chalmers units easier that the Farmall ones.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 11:23pm
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 5:59pm
I mentioned Traction Booster. For it to be it's best, the front of the tractor needs to stay down and in TOUGH plowing a couple hundred pounds makes a big difference. Dad never had any extra front or rear weights (just rear fluid) and we still got along fine, but I know it could have been better with a little more on the nose.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 5:56pm
Yea
I was gonna start a new thread on that .
That subject will be a consuming thread all of its own.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 4:53pm
When you guys are talking plowing, no one has even mentioned AC's Traction Booster. When the traction booster is set right, it amazes me how much difference it makes plowing.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 12:14pm
In central KS (1940's, 50's & 60's) the few AC dealers were small, the many JD and IHC dealers were large. Herb(GA)
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 11:46am
Maybe they are designed a decade apart is why.
Production data per tractordata.com:
Farmall H built in 1939-1953,
Farmall M 1939-1954
AC CA in 1950-1958.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 11:41am
Much easier to do a brake job on the Farmall's.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 11:34am
I’ll pull an Allis 3-16 plow with my wd without any weights, just 16.9R28 Firestones…
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 10:07am
In terms of Physics the Snap coupler and Fast hitch both essentially work the same way. The wishbone anchors up under the center of the tractor and hang off the rockshaft arms. FH the wishbone(and adjustments/settings)is attached to the tractor and SC the wishbone is attached to the implement(with less settings).
Edited by exSW - 19 Nov 2023 at 10:13am
Learning AC...slowly
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 10:01am
Originally posted by Macon Rounds Macon Rounds wrote:
More Farmall "M", 400's, 460, 560 etc in our area than Allis Chalmers .
But no one uses fast equipment anymore. Lots of tractors with it. But no one uses it.
But lots of snap coupler equipment being used. Especially for spring and fall plowing.
I'll plow with my 560 and 3-16" FH all day before I hook the WD to the SC plows. The WD does the garden because it's smaller and handier not because it does a better job.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 9:50am
To expand a little bit on Dave's comments, answer me this riddle: Take an "M" or even possibly a Super"M" Farmall and a 3 x 14's pull-type plow to a field of alfalfa sod to turn the soil over. On the same day, and same time, take a properly equipped WD45 gas with good cond 14.9 x 28 tires (factory option) and 900 lbs of fluid (standard equipment) between the pair. Also, have a couple of rear wheel weights on each rear tire and some front end weight too. Equip this tractor with an AC 3 x 14's 50 series plow properly adjusted and sharp plow shares. Which one should you put in the lead ???  As a package deal (from the selling dealership) you'd better put the WD45 in front, or you will be waiting all the time for the Farmall to get out of the way. I'm not saying a HUGE difference in performance, but the Allis will win and the longer the stretches are, the farther it will keep gaining distance. Traction Booster. A closely hitched and lighter weight plow. And an Operator that knows how to make use of what he has helps with the "win".
This is just my opinion, but I think the extra base tractor weight and larger diameter tires of the SM/400/450 let a lot of IH farmers (or anyone with a heavier tractor) be lazy about proper plow setup. I think you're alluding to that by stating properly adjusted plow, sharp shares, extra weight, etc. for the WD-45 in your case. The M was no longer in production when the WD-45 came out, and don't forget AC was still trying to compete with the WD-45 by the time IH had already released the 450, although the D-17 wasn't far away.
I'd wager either a good IH dealer with a Super M or a good AC dealer with a WD-45 could set up their tractor to outdo the competitor's tractor that had just had a plow hooked up to it with little optimization, or one that was getting a little worn and out of adjustment. An average setup 450 might even outdo your best setup WD-45, towards the end of WD-45 production.
My answer was to get a WD-45 AND a Super M! Both have their place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 9:24am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 8:19am
A lot comes down to preferance. I like a rowcrop platform tractor, that pretty much eliminates D series. AC made a lot of properly ballasting their tractors. IH just put the iron in the tractor.AC didn't do that till the 7000 series. IH's 300 and 400 series engines were the best engines of the era for one simple reason. They were the last developed. IH looked at everyone elses and sat down at the drawing board. The torque curve of these engine let IH go without a powershift for so long simply because they didn't need one. Same conditions,same fields same implements IH,AC,JD you're not reaching for that TA as often as you do the powershift.  There's slopes were I live and clay soil. But I've ran machines in the loess soil of West Tennessee and same thing. I like my 7010. I like the powershift. The cab beats a Soundguard to bits. But I'd trade it for a 5088 (if I could find one that wasn't slaughtered) in a heartbeat(although an 8030 would probably win over both. Cab and hydraulics). I love my WD as a tractor I wouldn't trade it for even a late battery box Super H. Fast hitch was the best part of those 50's IH. It flat worked. IH was foolish not to licence it. Snap Coupler is slick but it's not FH slick.
Edited by exSW - 19 Nov 2023 at 8:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 6:11am
Even with fenders on the IH tractors, you still were somewhat in harms way (no top to the fender) of the moving tire and how high you sat in the air. They were much easier to upset than a WD45 for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2023 at 5:03am
I guess my biggest complaint about the M was I didn't feel safe driving it. With the WD45, that I learned to drive on, the fenders (especially the right side) made a pretty safe environment. On the M, I felt like I could easily fall under the fender.
Adding to Dave's comments about patents, Power Adjust wheels (starting with the WD) was a huge labor saver and probably a big selling point.
The hand clutch setup was a great help for a kid learning to drive a tractor. I can remember starting and stopping with the hand clutch when I practically had to leave the seat to reach the foot clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 11:46pm
Edited by DrAllis - 18 Nov 2023 at 11:47pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 10:35pm
Running out of traction before horsepower is the reality of tractive effort physics... and tire diameter, in agricultural tractive effort, is a key element far greater than tire width, because the CHORD ANGLE at which the tire engages the soil determines when the TE slip curve starts it's rapid climb.  This is all illustrated in the empirical evidence study done by Wismer and Luth in their 1973 paper publication:
Adding ballast is another key factor, but realize that when engaging in a tractor pull, it is not the TRACTOR, or the TIRES, or the ENGINE that determines who wins or looses, it's the RULES that make the determination. If the rules predicate using stock tire size, and a green or red or yellow tractor used a larger diameter tire than an orange, then the natural advantage at any given weight, will favor the larger diameter, REGARDLESS of the width.
But that's not really the context of this thread.
The point to remember when comparing tractors, especially comparing BRANDS, is that manufacturing tractors wasn't about building the 'best' tractor, it was SELLING THE MOST tractors, and it wasn't about having 'ALL THE BEST' features, it was about having features that YOU controlled the PATENTS on.
The Allis Power Director was a very serious patent feature, it was a reckoning force of competition to the IH Torque Amplifier... because of HOW it worked, and it's competitor could, and could not do.
Now, in the realm of comfort, there weren't many tractors prior to the late '50's that had what we would nowdays regard to as 'good human engineering'... and part of it was simply the agricultural normals of the era.  Row cropping used to be very mechanical-cultivation-intensive... they'd plant in check-rows so that weeds could be cultivated out from several angles, several times a season, and as such, a good view, offset from centerline, was a big feature in tractors.  Power steering really didn't exist, but if you were rolling through rows, it wasn't massively necessary...
How each company addressed things like this... was highly restricted by PATENTS.
Now comparing IH to Allis in terms of business,   International Harvester's primary focus was the manuacture of machinery for the agricultural industry.  Their greatest asset, was their ability to reach out to markets worldwide, and to manufacture both domestically, and overseas.
The primary focus of Allis-Chalmers, was the manufacture of industrial and utility power equipment.  Farm tractors were a 'surplus product', in the shadow of massive generators, electrical transformers, steam turbines, etc.  Their greatest asset, was their foundry and industrial engineering capacity... it enabled them to pour huge components, and then use the excess material to effectively make large quantities of other parts, including engine blocks, transmission housings, etc., at a very low cost.  They were masters of Economies of Scale.
All this being said, comparing two TRACTORS isn't a 'which is better?' type situation... it is more a 'which is better for what circumstance, and why'.  In making up a side-by-side comparison/contrast chart, one will find that both have significant strengths and weaknesses, both have design elements and operational features.  In investigating the strengths, weaknesses, design elements and operational features, then looking at what was PATENTED, and by WHOM, you'll get a really good idea of why everything is as it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 11:59am
I believe you can replace a foot clutch in those Farmalls, without splitting the tractor ?? That's not a bad thing.
Yep, just on the very late Ms and newer...
< SNIP>
The bigger rear tires on the Farmalls give you better traction in field work but do cost more to replace. No spinout rims on the Farmalls - pro and con as the spinouts do cost more, but if you need them for cultivating different row spacings, they're handy.
<SNIP>
Dad likes the larger diameter wheels on the H, but I think you can mostly compensate with wider wheels and proper ballast.  Greater ground contact can be achieved either way.  I put wider spinouts and wider tires on the CA and plan to add liquid ballast and "properly" distributed weights.  I'm not quite sure what I'll be using it for beyond mowing yet though, but it'll be ready at least :)
I like to watch some of the youtube pulling videos but am sometimes dismayed at some trying to use very narrow tires on their Bs and Cs and CAs.  They usually end up losing traction long before they run out of torque.
Edited by dfwallis - 18 Nov 2023 at 1:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 9:52am
Yep, just on the very late Ms and newer (i.e. Super Ms) the clutch pressure plate is a little to big of diameter to fit out the bottom of the housing because they upsized the clutch. This still came in handy on my Super M because I needed to replace the input shaft seal and bearing. You're crouched under the tractor which isn't fun, but you can get the pressure plate, throwout carrier, and clutch all loose, cocked sort of sideways, and get the input shaft out to replace the bearing and seal. Definitely easier than splitting the whole tractor.
I think the CA would be better compared to a Super C, 200, and 230. They were made roughly the same years as the CA and were similar size. Those Farmall tractors could have true live hydraulics driven directly off the engine so that is a plus over the CA. However if you can keep the hand clutch on the CA in working condition, it does give you a form of live PTO and live hydraulics.
I do like the quick release hood latches on the Farmalls, compared to threaded fasteners on the AC hoods. The bigger rear tires on the Farmalls give you better traction in field work but do cost more to replace. No spinout rims on the Farmalls - pro and con as the spinouts do cost more, but if you need them for cultivating different row spacings, they're handy.
Mounted implements are a plus on the ACs. It's easier to find Snap Coupler attachments, I think. They are out there for the Farmall Super C etc. but don't seem to be as easy to find. Governors are also snappier on the ACs as another poster mentioned above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 7:49am
We had an H, MD and MDTA in the early 70's.
Dad was looking for something a little safer for us kids to plow with, so he bought our 1960 D17 and the IH's were gone shortly there after.
I do wish I had the 1954 MDTA back. Just because of what it is.
Allis was so much more comfortable and easier to drive. And more safe. To plow with, at least the D series are.
And baling hay with the power director was and still is a dream.
I recently bought a IH 400 tractors at an estate sale.
It was a VERY NICE well taken care of tractor.
After using it to disc and having the wife also try it out. We quickly sold it to an IH collector.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 7:23am
With the pto set up and hydraulics I'd go with a h over a wc but would like the wc motor better.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 7:11am
I grew up on Farmalls would take a H over WC any day ,Dad had a lot of attachments for the H .  WF a thread like this is going to jump around . It will be entertaining and opinionated .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 6:48am
Originally posted by 560Dennis 560Dennis wrote:
never owned and AC tractor so cant make a comparsion .
I do see them all at the auctions . All have issues from poor maintenance by the owner.
This Farmall is a piece of crap. Yep ! It is ! Look at what the owner did to it, nothing
I think the thread is more about the design than mechanical problems.
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2023 at 6:39am
