AC Traction Booster Gauge
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: AC Traction Booster Gauge
    Posted: 21 Oct 2011 at 6:34pm
Well, I thnk my hunt for an AC with a wide front is over. If everything goes as planned I will be going to buy it and bring it home Tuesday. No, it is not the WD45 that I posted on here. Anyway, the only fault that I can see with it is that someone has replaced the traction booster gauge with a second amp gauge (I'm picky you can tell). I looked it up and a new traction booster gauge that actually works is $100!!! Is there anything I should know about when I go to hook the new one up?? Is there anything else I should know about related to the traction booster gauge and system?
It has been converted to 3 point. I'll tell you what model tractor it is but I want to have a little fun with you guys first.
HINT: It is newer than the WD45.
Edited by AllisChalmers37 - 21 Oct 2011 at 6:34pm
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 7:03pm
If the 3-point conversion does not actually hook or link into the existing TB; other than esthetics, or being "picky" (as you say), there's no point in putting in a working TB gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 7:17pm
I think it does hook up.
Oh yeah, I couldn't resist. I guess my new avatar gives it away.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 7:19pm
  do you know its purpose???????/
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 8:51pm
Originally posted by norm[ind norm[ind wrote:
]  do you know its purpose???????/
What, the traction booster?? If so yes, it is used to detect the weight of the implement and adjust the amount of lift on the lift arms thus putting more weight on the rear wheels and giving more traction.
As for the gauge I don't exactly know.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2011 at 9:01pm
It's a D14
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
