AC TL-16 vs. Caterpillar 944
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: AC TL-16 vs. Caterpillar 944
    Posted: 13 Sep 2024 at 8:25am
Looking at old school rigid frame wheel loaders and have narrowed the field to the two choices above.  Would like to hear the pros and cons of these machines.  The chosen unit will work on topsoil and move 1,000 pound boulders to aid in building a stone wall.
Appreciative of any insights!  ~  Orangeman
Lee Bradley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee Bradley Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 10:50am
I ran a TL-12 that like the 16 has very far forward operator position this makes getting in and out more difficult but I prefer the visibility that provides.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 11:13am
Since you are looking at 60 year old machines with limited parts available. How many are expecting to come out of the woods if you put a wanted ad out?
You have a better chance to find Cat parts as they are still in business. But have found early wheel loaders used a lot of parts that are special to wheel loaders so they are hard to find.
So look long and hard before spending your money. Then it will still be a guess which has the most life left. Good luck picking a winner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2024 at 6:02pm
Lee and Ray54 - Thanks for the input.  In the case of the AC TL-16  I have a choice of three non running - one with a cab.  So likely would take all three to make one.  The Caterpillar 944A has a cab and ran recently but has a pony motor for starting.  As I understand, the early 944A machines came with a pony motor but can be converted to DC electric  start motor.   The 944 machines carried on as a 944B and may have served as the design basis for the Caterpillar 950 wheel loader.  I also understand that Caterpillar has few if any parts remaining for the pony motor.  So likely, that the machine would need to be converted to a direct electric start.   There is also a AC 840B with Cab that is running nearby and working but not sure I can convince the owner to sell at this time.  Again, certainly appreciate the insights.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 9:48am
all the old cat parts are shrinking fast  but thier are more of the cat stuff left than the rest put together
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 12:05pm
Hudco:  thank for those good insights.  Is the Cat parts availability better because they sold more units or just the fact that Cat still survives and had dealers that along with the company had stockpiles of parts and perhaps deeper stronger resources that allowed them to remain in the present rough and tumbler heavy equipment market place?  ~ Respectfully,  ~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 3:39pm
I think your logic is a little off...  Likely all three are wore out in the same places...Wink
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 6:26pm
I had a old 55 Pettibone T-11 machine for several years , and with a Detroit 3-71 , fwd /rev box, 4 speed transmission , torque converter with Allison box and clutch . Problem with any straight frame machine and rear steering is they seldom track in any movement without a lot of steering positioning.
 You could load from a pile . move to dump into truck , and not get back to where you loaded without a lot of maneuvering
 If it was me I would look for any articulated machine . A 1 ton rock should be no problem for any machine with a 2 yard bucket as for power to lift .
 Roading a straight frame means going in reverse as with steer in back they wander all over . All the old loaders with cab forward and loader arms behind operator can be widow makers , as access to operator station is over or under loader booms .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2024 at 9:59pm
i spent many hours on a 966a and when all the steering was at its best you had to rode it in reverse the one i run run had zero brakes  , i was real good at shuttleing it from forward to nutral to  reverse for braking  that was 40 years ago
7580/190XT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7580/190XT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 11:54pm
Well its a A/C forum so most like my self like A/C also. Have had my TL-12 since early 90s although it wasnt beat to fk and was maintained, some have gotten abused. Built pretty tuff but if operated not to brake um eeeh. I havnt had to use my Bridgeport or lathe on it as much as newer crap.
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 4:44pm
That's a great shot of a TL-12 in action.  More often than not you see photos of them painted in industrial yellow rather than Persian orange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 6:48am
7580/190XT - That's a darn nice photo of what a TL-12 can do! Still very useful after all these years and doing some reasonable chore work. I had a look at the Caterpillar the other day - couple of tires down, has a pretty heavy fiberglass cab on it with forks and about a 4 yard snow bucket.  Certainly too big for the boulders I need to move around.  All the gauges were in very nice shape.  This unit must be a very early one as it has the pony motor along side the D330 in it.  Next visit will be to evaluate the TL-16's.  I see a winter project in the making ~  Orangeman
ChrisR123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChrisR123 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 2:14am
How much are they worth now? I've got one in great shape that's running and it's a monster of a machine that I was interested in maybe selling
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2024 at 9:10am
I'd vote for the caterpillar path, just for parts available. Doing a restoration just for a restoration is different than getting a machine working to complete a project.
This channel does a lot of rescues, might even have some AC content. Tracks will give you more grip than wheels.
This channel did this loader and I think a second one.
Both may reveal common issues you'll find.
Edited by jvin248 - 23 Sep 2024 at 9:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 54 minutes ago at 8:32pm
JVIN248 - Right On regarding the parts support for the Cat 944 and given the numbers produced that is why the Caterpillar 944 is even in this discussion! Thanks for the link to the rescues - I like working machines that aren't parade queens.  The whole idea is to have something that can handle the task, has a reasonable long design life and parts either used or new can be obtained so the unit can run again and do work on a medium size acreage.  The rock wall is for privacy and to define a future planting boundary.  With my age slowly advancing and having a few minor (slow me down) health issues - now resolved - the open station of the Caterpillar for access and egress from the cab is far better than a climb, slide in cockpit arrangement.  I also see that the front mount loader arms provide a very nice safety advantage and the dimensions on the loader supports look to be very stout on the Cat as well.  At this point am leaning toward the 944, maybe add the AC TL-16's if my machine shed can be arranged to hold them - I do like the AC TL-16's and 20's they certainly would be a good choice too - just a little more stepping and stretching to get into the cab.   Thanks all for your valued insights ~ they are much appreciated.  Hope you all have an excellent fall season!  Respectfully ~ Orangeman
