A-C Stone picking machine
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: A-C Stone picking machine
    Posted: 20 May 2010 at 7:46pm
Spent part of the day picking stones on 110 acres of bean ground. After retiring the 715B from digging silo foundations, it became a farm machine. I built 8.5" axle extensions and enough hub for two rims and mounted 16.9 x 28 power shift rims from two D-17 iv's. Twenty years ago we made a quick detach bucket arrangment so with two pins it can either be a forklift, regular dirt bucket, 8' stone fork, or bale spear. This is my third A-C backhoe since 1974.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 7:54pm
thats a neat set-up you have
160 CA 920diesel 5020 HD-3
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 9:58pm
dang! you have that size bouders in your fields? and that is a nice setup!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2010 at 11:30pm
Dale, he calls them stones, kinda like what David put in his slingshot. I think they use the excavator for the boulders. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 5:56am
I worked that field last fall with a BlueJet Tillage Pro (7 shanks about 10-12" deep).
I usually work the wheat stubble with the BlueJet which is every 3 years. It always brings up a few big stones. Normally I get one or two buckets of 3" plus stones off 25 acres.
Anything that goes throught the fork stays.
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2010 at 7:54am
Nice machine and set-up you got there Calvin.
