AC running gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: AC running gear
    Posted: 25 Feb 2026 at 5:27pm
Looking at one but I don’t know what tonnage it is. Cat no 2051584, serial number 8-4437. My guess is it’s a 8 ton?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 6:27pm
It’s a model AC 800 running gear. Yes 8 ton. It should have its reach pipe that goes straight through the rear frame & then is flatten & becomes its rear hitch.
Edited by AC7060IL - 25 Feb 2026 at 6:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2026 at 11:09pm
Would it extend enough to make a 16’ hay wagon?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 7:18am
16’ hay rack? You decide. Maybe if it allows for 5 feet of overhang? Overhang could be combination that includes both front & rear frames(wheel base). Typically, the front overhang is less than rear? I’d put more emphasis on its hitch tongue length per it’s application.
Standard tongue 72”.
Adjusting tongue with spring lock pin ~ 90” & could be extended.
Which tongue is it?
The wheel base info was listed on their OEM sales brochure. I don’t have an AC sales brochure for the 800 (era 1969-72?).
I do have its predecessor 1966 OEM sales brochure FE379-668 for the AC 701 (7ton) & it states;
-Track: 75”,
-Wheel base: 7’-1” to 11’.
-Turning Radius: 11’ (7’-1”),
-Stake adjustment: 38” - 42”,
-Weight: 510 lbs.
Edited by AC7060IL - 26 Feb 2026 at 7:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 7:47am
Here’s a 2024 link where Mikez posted a 1969 AC dealer’s order sheets for running gears. On his 1st page near the bottom, it list “extra length telescoping poles”.
So it was an option.
Maybe try extending the 800 & if it’s not to your liking, buy some pole pipe & fab it to your desired length??
https://www.allischalmers.com/forum/ac-wagon-or-running-gear_topic7559_page2.html
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 2:50pm
Mine has a 16' deck on it.  Used to be a forage wagon, but still has the standard length reach with the flattened end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2026 at 6:26pm
Dseries4, Thanks for sharing about your 800 gear & hay rack. It looks great. Thinking it’s fully extended? If so could you please measure it’s wheel base?
Edited by AC7060IL - 26 Feb 2026 at 6:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 9 minutes ago at 8:50pm
Exactly 11'
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 1 minutes ago at 8:58pm
11 ft gear 1-2 ft overhang on the front and 3-4 ft overhang on the rear for a 16 ft rack.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 12 minutes ago at 5:47am
If the wheelbase is 11' (center-of-spindle to center-of-spindle), one foot of overhang on the front probably won't get you to the front of the rack being even to the front of the tire.
If the cross pieces on Myron's rack are 2" x 10", he has pretty close to 40" overhang from the center of the rear spindle. If that is the case, he should have about 20" overhang on the front.
Edited by WF owner - 5 hours 1 minutes ago at 5:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 6 minutes ago at 7:53am
I haven't measured the overhang, but I do want to move it forward one of these days.  It's pretty far back and it has a long tongue, so there will not be any problems
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 48 minutes ago at 8:11am
It looks ok to me. I have seen wagons with a lot more overhang than yours.
This page was generated in 0.191 seconds.
