AC running gear |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5415 |
Topic: AC running gearPosted: 15 hours 9 minutes ago at 5:27pm |
Looking at one but I don’t know what tonnage it is. Cat no 2051584, serial number 8-4437. My guess is it’s a 8 ton?
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3645 |
Posted: 14 hours 9 minutes ago at 6:27pm |
It’s a model AC 800 running gear. Yes 8 ton. It should have its reach pipe that goes straight through the rear frame & then is flatten & becomes its rear hitch.
Edited by AC7060IL - 13 hours 58 minutes ago at 6:38pm |
AC720Man
Posted: 9 hours 27 minutes ago at 11:09pm |
Would it extend enough to make a 16’ hay wagon?
AC7060IL
Posted: 1 hour 18 minutes ago at 7:18am |
16’ hay rack? You decide. Maybe if it allows for 5 feet of overhang? Overhang could be combination that includes both front & rear frames(wheel base). Typically, the front overhang is less than rear? I’d put more emphasis on its hitch tongue length per it’s application.
Standard tongue 72”. Adjusting tongue with spring lock pin ~ 90” & could be extended. Which tongue is it? The wheel base info was listed on their OEM sales brochure. I don’t have an AC sales brochure for the 800 (era 1969-72?). I do have its predecessor 1966 OEM sales brochure FE379-668 for the AC 701 (7ton) & it states; -Track: 75”, -Wheel base: 7’-1” to 11’. -Turning Radius: 11’ (7’-1”), -Stake adjustment: 38” - 42”, -Weight: 510 lbs. Edited by AC7060IL - 1 hour 15 minutes ago at 7:21am |
AC7060IL
Posted: 49 minutes ago at 7:47am |
Here’s a 2024 link where Mikez posted a 1969 AC dealer’s order sheets for running gears. On his 1st page near the bottom, it list “extra length telescoping poles”.
So it was an option. Maybe try extending the 800 & if it’s not to your liking, buy some pole pipe & fab it to your desired length?? https://www.allischalmers.com/forum/ac-wagon-or-running-gear_topic7559_page2.html |
