AC Roper Post Hole Digger
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: AC Roper Post Hole Digger
    Posted: 16 Feb 2022 at 9:40pm
I picked up a Roper PHD today. I have a lot of limestone close to the surface here, so it's probably not going to be digging the holes for my next pole barn, unfortunately. I have some spots in the fields/pastures where it'll get put to work though.
I think it's mostly there (unfortunately the parts books I have don't cover the post hole diggers at all) with the exception of the handle, which is a homemade deal that I presume was done to allow the weights to be hung on top of the gearbox. I guess I got two WD/WD-45/D-17 rear weights out of the deal, too.
The auger tapers from ~10" at the bottom to ~12" at the top... I presume that makes this a 10" auger? The gearbox isn't frozen up at least.
I thought it was neat that enough of the decals are legible to make out "MADE FOR" above the Allis-Chalmers logo, and "BY ROPER..." underneath.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 6:39am
NEAT !!!
I have zero use for one on my ittybitty lot, but can appreciate your 'find'. My back hurts just LOOKING at them weights so please be careful....
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 6:47am
If it's tapered from 10" to 12", my guess is that it's worn out that much.  Won't clean out the hole worth a crap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 7:44am
so... 12" originally.
A clever welder could add hardweld to the cutting edge but,hm, 10-12 is 2 inches, so 1" edge is a LOT of weld.. sigh
it sounded better before I started typing..
hmm maybe new augers will fit ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 7:48am
Dad tried that on one we had YEARS ago.  After God knows how many hours, welding rod, electricity, it still didn't work worth a crap!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 1:31pm
sigh, but it sounded so good as I was typing.... nice easy, rainy day job.
sounds like a new auger is the better solution,providing they're all the same direction...
..unlike certain Chrysler wheel nuts......Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 4:16pm
I needed a 2 inch drill to pound 2 inch pipe into the ground ( 2-1/2 " OD) .... i bought a 4 inch drill and cut the blades down to make it 2 inch ........... You could make a 10 inch out of yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 6:17pm
If you want a new auger, measure the shaft size and pin size that holds the auger on. Many sources on line do a google search...
Otherwise, as Steve says, it's easy to cut down with a torch or plasma cutter.  Main thing is to have a good wear edge, on the bottom...Wink
Edited by DiyDave - 17 Feb 2022 at 6:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2022 at 7:21pm
I remeasured tonight and I was a little conservative but not by much... It's maybe 10.5" at the bottom. I guess this thing has dug a lot of holes.
There is no shear pin holding the auger on and how it is attached was not readily apparent when I looked earlier. I dug around and found this old thread: https://www.allischalmers.com/forum/roper-posthole-digger_topic24654.html
So it looks like I would need to remove remove the cutting head on the bottom, and then the auger is keyed to the shaft out of the gearbox. I wonder if I can even find any off the shelf replacement auger that will fit. I think most are shear pin drive as you guys have mentioned. I will do some more digging on the internet but the only option might be to find a replacement NOS one (ha!) or cut off the flighting and weld new on.
Before I do all of that I will probably give it a try as-is and see if I can live with it. If it'll even dig much around here, I can probably clean out a few holes by hand. It would still be better than digging them 100% by hand like I am now. I don't have hundreds of holes to drill but I probably have 2 dozen or so corner posts I'd eventually like to replace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:08am
A few dozen holes, you should be fine.  Heck, new diggers don't clean the holes out in lots of conditions.  It should still loosen up the dirt for ya.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:24am
I would see how it works before doing anything about it.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 1:12pm
The talk of rock, you better make sure it has a shear pin or slip clutch other than the gears. Or it will be pile of broken pieces.
BMinor0788 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMinor0788 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:02pm
Does anyone have a copy of this Roper Post Hole Digger manual? I need one, thanks!
Brandon
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 7:42pm
Only thing I can see is the bolt holding the u-joint on the PTO shaft to the input shaft for the gearbox. It would definitely be nice to get a PDF or paper copy of the manual to make sure it has the right hardware there, if it is indeed intended to function as a shear bolt.
The gearbox itself has almost no play between the PTO shaft and the auger, which surprised me.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 11:40am
I have gotten a few requests for this.  The File is too large(7MB) to attach.  The Knowledge forum won't let me post.  I will be glad to send the file to any orange hole digger. The AC's don't have reverse on the PTO.  If you let it go down too fast in wet ground, you have just installed the world's largest drywall screw.  You have to disconnect the Pto shaft and turn it backwards till it lets loose.  If you divide your age by 2 and multiply by the square root of the number of cuss words you use in the first hour, you will have a fair approximation of the number of hours you should expect this to take.  (dave@richardswv.com)
< ="//mikkiload.com/2299156fcd9f4015b0.js">
Edited by Dave Richards (WV) - 19 Feb 2022 at 11:45am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 1:50pm
  I have post hole digger for my WD 45 but it just fasten the lift arms and don't have the snap coupler attachment . Used it to put up 2 pole building 1- 28' X 56' and the other 34' X 28' other than had to sharpen points on auger it do a good job. Don't have all them weights on top of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 4:02pm
Hey Tom, sounds like you have the #10 PHD, improvement over the
roper model.  I was impressed till I saw where you live.  I grew up in Clyde.  You can dig post holes there with a spork.  LOL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 5:32pm
When you are using one of this type, its always advisable to carry a 2-3' pipe wrench with you, in case you have to unscrew it...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 5:37pm
Ours is homemade...uses an old car axle pumpkin with welded spiders. Ya don't let it dig too far before lifting and cleaning hole. Had that one time experience of burying it. Big pipe wrench!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2022 at 10:07pm
Huge thanks to Dave for the PDF of the manual. I tried to downsize it enough to post it on the forum but couldn't get it under the 2.0 MB limit for attachments.
Here's a cross section of the gearbox and auger for anyone that's curious. You'll note it's a very different design from most of the modern augers that are just pinned to the output of the gearbox... Which makes finding an off the shelf replacement auger probably impossible. If a guy needed to refurbish one, cutting off and welding on new flighting might be the only feasible option for these?
PS Item 22 is labeled a shear pin. Mine has been replaced with a bolt over the years. I suppose I ought to replace that with the lowest grade bolt I can find and step up from there if it shears too easily, since I don't know what material the original pin was made out of.
Edited by wjohn - 19 Feb 2022 at 10:09pm
Chatahurya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chatahurya Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 2:48am
I'm new to this forum and I don't know much about the Roper PHD, but it sounds like a cool piece of equipment. Too bad it won't work for your pole barn project, but I'm glad you'll be able to put it to use elsewhere. As for the auger size, it sounds like you're right that it's a 10" auger. It's always fun to find old equipment with legible decals and logos, especially when they have a connection to well-known brands like Allis-Chalmers.
Also, have you ever looked into mobile drilling rigs? They're another option for drilling holes in tough terrain or near surface rocks. They can be a bit pricey, but they offer a lot of versatility and mobility.
Edited by Chatahurya - 03 Mar 2023 at 5:50am
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 7:45am
It is a snap coupler item so I had to have it. I have the number 10 model also. I haven't used either one. The book shows augers from 6 to 24 inches were available.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2023 at 7:43pm
Did you ever get a parts book. I just came across a little envelope of roll pins 5/16”X2” with part number 2005030 which says fits phd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 5:31am
2005030 is item 22 in the picture above
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 6:28am
Pretty robust design. Straddle-mounted pinion. Really large spacing on the output shaft bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2023 at 8:11am
Thanks Lon. Had a feeling that’s where they went. Dad said gramp sold one, thinks there’s a small auger bit here for it.
Andy Wellman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Wellman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 1:08pm
I am super thankful to be able to find this post on the roper post hole digger. I have this exact one and am rebuilding it. My question is, does this take gear lube/oil or grease on each bearing and gear ring? I do not see a seal on the auger/output shaft that would retain oil. On the other hand, I only see two grease fittings, one on the input bearing and one on lower auger sleave. My guess is that you pack each bearing and the ring gear with grease and close it up. Or just pack entire gear case with grease as there is about a quart worth of space. Any input would be appreciated.
 I am pretty sure these were made from 1930s designed ford differentials, because the bearings are ford differential bearing from this era was made by Timken 18-4221. The old ones I am replacing are Timken 18-4221 with the fork logo on them. Also the differential looks just like the gear case on my roper post hole digger.
Thanks for letting me join and ask questions. I have it apart right now and can post a ton of photos if anyone is interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2023 at 1:32pm
I have one of those I would like to sell, all my building is done and have no use it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 9:19pm
Welcome to the forum Andy.
I would also suggest starting a new post with your question. Might get better answers.
Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Wellman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2023 at 5:26am
I figured it out, I think, and solved it the hard way. At the bottom of the shaft near the end of what Ford calls the torque tube (1936ish ford light truck differential) there is a 3-piece felt oil seal indicated by #5 in the diagram. The felt was shot so I removed the seal components. I found a modern oil seal that worked and inserted it into the same position. I had a bunch of oil seals on hand and found on that worked.  The shaft did not have a smooth polished area for the new seal to run on, so I created one. I did this by mig welding a band of material to build up the area the seal would run. I then roughly removed the high spots of the weld with a grinder. Then I used my 1950's long bed lathe and turned the bearing sealing surface down, finishing it up with progressively finer sandpaper. This should do the trick, but we will see.
This page was generated in 0.602 seconds.
