AC rat rod
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: AC rat rod
    Posted: 31 Oct 2018 at 9:00pm
considering a rat rod project with a 301 diesel turbo engine. Any idea what tranny might bolt up or be a good candidate for rpm and gear ratio?
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 6:57am
Ratios will all depend on what size tires you plan on using. Here’s a bit to go on. I had a 69 Astro with a 2100RPM 238 and a RT910 with a 4.10 rear using 10.00X20 tires. It would do about 65 flat out. Then I got a 79 model with a 1900 RPM Formula 290 mated to a RT9509. That would top out a little faster. Now my 93 pickup with the Cummins and manual w/overdrive as ordered from the factory with a 4.10 and 233/85/R16 would go abot 85 with the motor turning about 2500RPM. You need to decide more of what you are planning on ending up with and do the math.
