AC pumpkin planter!
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Topic: AC pumpkin planter!
    Posted: 13 Mar 2017 at 8:12pm
Have any of y'all ever tried to plant pumpkins with a plate type AC corn planter??? If so which plate did ya use? Soybean plate? Thanks
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 8:26pm
Even with the plates slowed down as far as you can, wouldn't the plant density be too high?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 8:30pm
You could fill in the extra openings to every other one or every third one or even fourth. Then pull it across some pavement and measure the drop rate.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 8:48pm
call Lincoln Ag Products     sales@lincolnagproducts.com
They have the plates and adaptors if you don't have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 10:07pm
JD has a pumpkin plate that will work, still available threw parts.  But yes you can take a corn plate and fill all the cells but 2 or 3 spaced out. Then grind the cells a little longer to fit a pumpkin seed.  Andy
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 11:13pm
I used to use a jd planter for pumpkins before I got my vacuum planter.  I got some steel blanks either from the jd dealer or Lincoln, don't remember now.  Ground out slots for different size seeds on different plates.  Changing the sprockets got it turning slow enough to plant on 30" - 36" spacing.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 11:33pm
I always wanted to try to set up planer for pumpkins.
We are just using our old new idea transplanter and dropping seed into the opening, works good
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 6:57pm
Ok thanks for the info!!! I'll let y'all know how it goes!!
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 6:59pm
Yes that's what I'm afraid of. Even with a 20 cell bean plate and as slow as it will plant it is pretty heavy!
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 7:39pm
How many acres are you planning on planting?
