AC power unit
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: AC power unit
    Posted: 18 Oct 2010 at 7:32pm
Does anybody know anything about this pu. I believe it's a w25 , but don't know I can't seem to be able to find any info on these. how you tell them apart & what it's suppose to have for a hood and if the gas tank should be the same as wc or something special ? All I know is it was orange then red, then green, & it's now mine. Serial # on clutch housing; PU28167W.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 8:24pm
  a w unit is a 2 cylinder   not a 4 cylinder  have seen 3 of them   listed in the construction book [ norm swinford]   1-574-342-4545
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:47am
Hope this helps. Chad
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 6:56am
How does the pony engine work in the first picture?  I see a spark plug but no wire.  How is it started?  No rope!
OH!  Oh!  I see,  its just a plug!!! LOL
Looks like a good candidate
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 11:57am
Looks like a W25, which would be a W201 eng, WC radiator, hood, diferent fuel tank and air cleaner. and a two fuel manifold!! Early power units did use the WC fuel tank. Yours has had some mods to it!!!!! The top mounded gas tank and angle iron are not part of the original package.   Usually the first thing to go is the side shields.  I have a power unit hood and gas tank, but not side shields.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 8:07pm
  the w is a 2cylinder engine   not W25    W ENGINE IS A 10 HP.  CONSTRUCTION BOOK
   UNDER GRADERS
