AC One-Eighty/185 left side lever? |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3661 |
Topic: AC One-Eighty/185 left side lever?Posted: 21 Nov 2020 at 1:52pm |
What’s the lever located on the left of a One-Eighty’s & 185’s steering wheel operate? Thanks
Edited by AC7060IL - 21 Nov 2020 at 1:58pm |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 21 Nov 2020 at 1:58pm |
The pto, can be mechanical or hyd.
AC7060IL
Posted: 21 Nov 2020 at 2:01pm |
Ok, so was hydraulic pto an option only? Is there any indication(decal?) of mechanical vs hydraulic pto?
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 21 Nov 2020 at 5:08pm |
WOW, very good questions
![]() . Our 180 has that particular lever, and I just assumed that that automatically meant "hydraulic" engagement. Now I am looking forward to a reply from Doc/Mac/Tbran
ksbowman
Joined: 19 Mar 2013 Location: Paola, Ks Points: 228 |
Posted: 21 Nov 2020 at 5:27pm |
On my 180 it is the hydraulic PTO
Mikez
Posted: 21 Nov 2020 at 5:34pm |
Look down under tractor at the pto drop box. If there's hyd lines going to it its hyd pto. And good question on if there was decals
FREEDGUY
Posted: 21 Nov 2020 at 5:36pm |
Just what do you have?? A 180 or a 185 ??
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3630 |
Posted: 21 Nov 2020 at 7:57pm |
Many years ago two older gents came in and ask what were the 2 levers for on the left hand side of the steering wheel. I informed them there were never two levers there and explained the function of the linkage for mechanical and hydraulic operation. Three days later they brought me pictures of TWO levers on the LH side... !!!! I sent the pictures to Norm Swinford and it stumped him. He checked around and at one time there was an engineering exorcise to allow the pto to be decoupled so as to be able to be connected with the engine running ,,, lost the photo but the guys at the shop still make fun of me being showed up by to elderly gents. Norm said that one was probably let go or sold at surplus with out removing the extra lever... just a bit of trivia...
Unit3
Posted: 21 Nov 2020 at 9:26pm |
Tbran, if one tractor had it, would there be drawings on a parts book page? If one tractor had it, how many more would-a, could-a had it?
tbran
Posted: 22 Nov 2020 at 2:50pm |
no as stated it was an engineering exercise which Norm stated most likely - it proved too costly and not enough demand - was sold as was the series VI D 17... No one ever saw another that I know..
FREEDGUY
Posted: 23 Nov 2020 at 4:55pm |
Where would the "mechanical" engagement lever have been located on a 180/185 ??
Posted: 23 Nov 2020 at 6:11pm |
Same place as a D-17. Very close to the clutch pedal pivot, which on a 180/185 is behind the battery box.
FREEDGUY
Posted: 23 Nov 2020 at 6:26pm |
Thanks Doc
Not to change the subject on models, but where was the lever/rod for the pto engagement on the WD ? I'm drawing a complete blank as I was only 8 years old when we ran one ![]() Edited by FREEDGUY - 23 Nov 2020 at 6:32pm |
DougG
Posted: 23 Nov 2020 at 6:29pm |
Was it the same as a 170 ?
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Posted: 23 Nov 2020 at 7:29pm |
Similar but not the same I believe, The 170 had the d-series style torque tube with mechanical power director and no option for dual or hyd pto. The 180 had updated bigger torque tube with hyd power director and room for hyd pto clutch, but the lever to actuate the pto coupler comes out of the housing in the same location, right under where the p.d. clutch sits in the housing.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
MACK
Posted: 23 Nov 2020 at 9:13pm |
Late 185s did not have the disconnect on outside.
WD was bolted to steering post down by brake pedals. MACK
Don Jr NY
Joined: 11 Sep 2009 Location: Waterloo NY Points: 376 |
Posted: 24 Nov 2020 at 3:45am |
I have a 185 with the mechanical pto and the engagement lever is in the same place as the hydraulic engagement lever which is on the left side of the instrument panel. There is a rod going from the lever down to the arm that is located behind the battery box. Hope this helps. Don Jr.
FREEDGUY
Posted: 24 Nov 2020 at 5:08pm |
Thanks Mack, was it a "pull" lever by any chance ?? Side note, did the WD have the ability to "lock" a brake pedal for stationary type work ?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8966 |
Posted: 24 Nov 2020 at 8:38pm |
WD & 45 locked both brakes with a cam attatched to a pull rod. Set em hard or you'll hear that "clank" and away she goes.
Edited by SteveM C/IL - 24 Nov 2020 at 8:40pm |
MACK
Posted: 24 Nov 2020 at 8:45pm |
The WD was a pull push knob. MACK
