AC Model D Grader
kgerhardt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kgerhardt Quote  Post ReplyReply Direct Link To This Post Topic: AC Model D Grader
    Posted: 26 Mar 2017 at 12:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kgerhardt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 12:11pm
I have a 1960 Model D AC motor grader.  I'm in need of the transmission brake band.  Does anyone know where I can get one or do I need to have my existing repaired with a new shoe and riveting?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 12:53pm
there is a guy named Rick on the forum here that does all sorts of clutch and brake re-linings. He usually runs ads in the classifieds. I'll see if I can find him for you, unless he sees this and jumps on it. Darrel
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 1:24pm
Any good brake shop should be able to re-line the band.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 1:42pm
Ken...I sent you a private message in regards to the brake band.   Rick
Hillbilly6778 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hillbilly6778 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 5:20pm
Just bought a 1952 Model D Motor grader and the lining on the band is worn down from 3/4 of it. Did you ever get yours replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 12:58pm
When I had my D grader I took the brake band to a brake shop and they had no problem installing a new lining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hillbilly6778 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 1:00pm
Perfect thanks. I can’t find anything online so that is what I am going to do. Just need to dissemble it without breaking anything.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2017 at 1:33pm
I can reline your brake band for you, so send me a message and we'll go from there, if interested.   Rick
