AC model B generator
stevebei View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevebei Quote  Post ReplyReply Direct Link To This Post Topic: AC model B generator
    Posted: 23 Jul 2017 at 5:50pm
I'm working on a 1948 model B. Can someone explain to me how to convert a 3-brush generator to 2-brush operation so that it will function with a voltage regulator. Thanks.
1948 Model B
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 8:48pm
You could take out the third brush but all it does is limit the charging current. You need to have a voltage regulator for the field winding and that's all it takes. Without the third brush the voltage regulator is the current limiter and includes the cutout that was used with the third brush generator.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevebei Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2017 at 1:02pm
Thanks Gerald. I removed the third brush and connect the wire to the "A" brush. It works fine now with a voltage regulator.
1948 Model B
This page was generated in 0.060 seconds.
