AC Lincoln 225 arc welder GURU,,S000..............
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: AC Lincoln 225 arc welder GURU,,S000..............
    Posted: 20 Sep 2025 at 12:35pm
 I got an OOOPS with my long time Tombstone arc welder. At one time I thought I would replace the old arc welder with a lincoln 175 mig,,,but after many spools of wire,,i really still like that old arc machine,,,!!
 I was doing some work on my car trailer and noticed that the insulation on both the work and ground cables coming thru the front of machine were just about frayed in to and fixing to start arcing to the metal box,,,,!!
 I took the panels off that gave me access to the work and ground cable connections and made new ends after cutting back the frayed cables,,,Man,,that was close and most likely "SAVED" the welder and prolly me too,,,!! Assembled the panels and gave it a test run and,,,,and,,,,you cannot hardly turn the heat selector knob in front,,,!!  I did not move anything on that part of welder and can't figure why as it had worked great brfore I changed the cable ends,,,,????
 Finally used a flat screwdriver and wedged behind the selector knob and got it to switch but hung up soon as I removed screwdriver,,,,??
 What the hey,,,??
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 2:15pm
I don’t know…..must have the panels binding it somehow. Take off or loosen the panels and see what happens?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 3:48pm
Opted to a 240v Suitcase Inverter welder, Never again will I go AC, Cleaner, faster, better performance.  Old welders had their place, are out of the game these days.  Sitting here on my Miller 210 Wire Feed, another great Choice on My part.
Edited by DMiller - 20 Sep 2025 at 3:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 4:15pm
Joe, its been a few years since i used the Buzz Box... dont remember exactly how it is made.. When you TIGHTENED the LUGS on the new cables, did that put a little TWIST in the selector switch or is frame ?
Might need to loosen the bolts and reposition.. Sometimes a washer can be installed under a cover bolt and get a little extra clearance..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 4:26pm
Joe , I've had my ac-225-s buzzbox since 1987. replaced the amp switch 10 years ago. I talked nicely to the Lincoln OFC girli and got the switch for $40. Yrah kinda pita but cheaper than what the repair guy was going to charge.
 I now PUSH IN the knob a bit BEFORE turning it, seems a LOT happier doing that.
Thanks,  YOU just reminded me I need to replace the cables,  I have a complete working spare unit LESS THE CASE TIN. Seems 'someone' saw it outside, deemed it SCRAP for HER 'contractor' son.....sigh........
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 7:36pm
Glad to see you are repairing it.
My father, using his 1950s machine shop welder would lay the cables on the ground three feet apart because all the insulation had flaked off, seeing that my brother and I bought him a new set of cables!
Be safe out there, it's not the voltage but the amps that are most dangerous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 9:59pm
 Well,,I fired up the Tombstone this morning and after "listening" to it run,,,I believe ole TBone and Steve are on right track as "something" mayhaps be loose inside as it is making a vibrating noise when I strike an arc then noise goes away after a bit,,,,??I know I got all the panels tight but it may be the connector on the work lead as the old lead had been bent for clearance on the back of the selector switch  and I just rerouted it,,,but don't think it put the selector switch in a bind but we'll know in the morning for sure.
 I also recently bought a new 120/240 invertor arc but haven't given it enough practice time and I should do so and save the old timer,,,,!!!
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:23pm
I haven't done this on welder leads but have on furnace igniters, which are high voltage but no amperage.  I cover the wire with heat shrink tubing to repair insulation.  Where I couldn't use heat shrink, I would coat cracked ceramic insulators with fingernail polish.  Fingernail polish is a great insulator, I found out one below zero night out of desperation, trying to get a family heat on an oil furnace with a cracked igniter shorting out an not lighting, thank goodness there was a lady in the house with experimental product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 59 minutes ago at 9:04pm
   OK,,,you guys are AW-SUM,,,,,!!  The lead hold down clamp had been,,,UMmm jury rigged by previous  owner and danged if I didn't copy his FU when I assembled the work lead to the back of the switch,,,,NOW,,I know better,,,!!
  there is one thing that is puzzling me,,I been modifying my car hauler with a Dovetail Addition and since I am more comfortable with this Tombstone I been using it in lieu of the Lincoln Mig 175 or even the new 120/220 Invertor,,,,I started noticing that several of my welds were "cracking" longwise  right down the middle on the bead,, Then the next two welds would be ok,,,??
 Anyone got a clue,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 20 minutes ago at 10:43pm
Cracking welds normally mean your using a HARD ROD .... or the metal is COLD .... or you need a Pre Heat with some "special" rods....... 7018 and the  60xx rods should NOT crack..
you might try warming the weld area up to 200 degrees with a torch prior to welding... Could be the BASE metal composition is not MILD steel..
Edited by steve(ill) - 17 hours 18 minutes ago at 10:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 40 minutes ago at 7:23am
 Well, Steve,,I was using some 6011,,,then 6013,,still cracking so I tried 7018 ,,all in 1/8" and at 75 heat setting,,,  It is not near cold yet but the size difference of the two metals was welding 1/8" to 1/4". I have a little bit left before I start the painting so I'll give the pre-heat a try this morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 39 minutes ago at 1:24pm
does not make much sense unless something in the BASE Metal... I use 7018 in a 3/32 rod 99% of the time.. Weld anytime is abouve 40 degrees and never need a pre heat.. Only cracking i have had is with cast iron or stainless material..
