AC Lincoln 225 arc welder GURU,,S000..............
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: AC Lincoln 225 arc welder GURU,,S000..............
    Posted: 5 hours 8 minutes ago at 12:35pm
 I got an OOOPS with my long time Tombstone arc welder. At one time I thought I would replace the old arc welder with a lincoln 175 mig,,,but after many spools of wire,,i really still like that old arc machine,,,!!
 I was doing some work on my car trailer and noticed that the insulation on both the work and ground cables coming thru the front of machine were just about frayed in to and fixing to start arcing to the metal box,,,,!!
 I took the panels off that gave me access to the work and ground cable connections and made new ends after cutting back the frayed cables,,,Man,,that was close and most likely "SAVED" the welder and prolly me too,,,!! Assembled the panels and gave it a test run and,,,,and,,,,you cannot hardly turn the heat selector knob in front,,,!!  I did not move anything on that part of welder and can't figure why as it had worked great brfore I changed the cable ends,,,,????
 Finally used a flat screwdriver and wedged behind the selector knob and got it to switch but hung up soon as I removed screwdriver,,,,??
 What the hey,,,??
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 28 minutes ago at 2:15pm
I don’t know…..must have the panels binding it somehow. Take off or loosen the panels and see what happens?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 55 minutes ago at 3:48pm
Opted to a 240v Suitcase Inverter welder, Never again will I go AC, Cleaner, faster, better performance.  Old welders had their place, are out of the game these days.  Sitting here on my Miller 210 Wire Feed, another great Choice on My part.
Edited by DMiller - 1 hour 54 minutes ago at 3:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 28 minutes ago at 4:15pm
Joe, its been a few years since i used the Buzz Box... dont remember exactly how it is made.. When you TIGHTENED the LUGS on the new cables, did that put a little TWIST in the selector switch or is frame ?
Might need to loosen the bolts and reposition.. Sometimes a washer can be installed under a cover bolt and get a little extra clearance..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 17 minutes ago at 4:26pm
Joe , I've had my ac-225-s buzzbox since 1987. replaced the amp switch 10 years ago. I talked nicely to the Lincoln OFC girli and got the switch for $40. Yrah kinda pita but cheaper than what the repair guy was going to charge.
 I now PUSH IN the knob a bit BEFORE turning it, seems a LOT happier doing that.
Thanks,  YOU just reminded me I need to replace the cables,  I have a complete working spare unit LESS THE CASE TIN. Seems 'someone' saw it outside, deemed it SCRAP for HER 'contractor' son.....sigh........
