AC HD6
Fortsville View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fortsville Quote  Post ReplyReply Direct Link To This Post Topic: AC HD6
    Posted: 22 May 2021 at 2:50pm
Can anyone point what to look for in my purchase. Someone is selling an HD6.  It’s a diesel I’m not too sure what kind of engine. It runs good just one steering clutch is screwed up What else do I look for? Price is $3500. It starts and moves.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 3:19pm
The HD6  have a 344 motor  ALLIS CHALMERS and about stering cluch he maybe just need adjustement and if the track chaine and sprocket are in resonable condition it't a bad deal.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 11:16pm
I've had those. Later units have a heavier bottom end inside the motor. Steering clutches come out the top. If its stuck, sometimes you can put a plug in the bottom of the steering clutch housing, pour about 10 gallon of premium #2 diesel into the top of the steering clutch compartment, leave it set for several days and it might come unstuck. The main clutch should be an oil clutch while the steering clutches are a dry clutch. What is it doing or not doing? Do you have a serial number?
This page was generated in 0.672 seconds.
