AC HD20 TORQUE CONVERTER ISSUE?
calvin long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 8:03pm
Originally posted by Mactractor Mactractor wrote:
I,ve wondered about operating rear mounted cable controls that way Cal. As old age and weakening shoulders become prominent.....
Everything is super tight from what I could tell on this Dozer it has 2227 hours on it I checked out rear cable units and they look like they're fully functional and had been well-maintained still got yellow paint on it from Factory and cables are great as well. I have just made it out to the pasture 1/2 mile hike through a narrow Trail after work today she's ready to come home to Daddy hopefully Thursday my buddy will back up with his 80k lowboy and she will be to our final destination in about 15 minutes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 8:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 6:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 6:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 6:23am
We made it to the pasture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:04am
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 3:02pm
ground shaker
HD3
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 3:44pm
" ground shaker"
As we watched and felt a HD 41 slowly go by one comment was
"That will have the ants grabbing for their crockery"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 6:06pm
Get that all functioning well then find a blade to mount to that U-frame, be a dirt pushing beast.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:16pm
And a 314 or 315 scraper hitched up. The cable control is already mounted.
Steve allis dozer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve allis dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:32pm
Nice tractor Calvin have you had a good look on the property for the blade ?  just a thought , it would be pretty heavy to move without the machine is probably still sitting where it was taken off
rickv57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickv57 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:50pm
That sure is a nice looking old 20 glad you got her going
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 9:19pm
I do have blade its a cat blade. Brought it home the other night. Also have another stump blade i need to get that goes with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 9:20pm
Thank you. Im 27 and i have real respect for the old equipment and the operators that ran them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 4:46am
The rather low hours, on it may come from the fact that it came set up as a stump ripper...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 6:34am
Would anyone happen to know where i can buy good replacement oil ilters and fuel filters for the HD20? I have had bad luck in the past with those old style cartridge types fitting correctly. Just want to get the right ones. Andy help wod be appreciated. Heres a pic of 1 of the oil filter housing.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 9:23am
  Part Number Manufacturer Wix Part Number
079352 ALLIS-CHALMERS 51133
straight from with wix interchange.  just punch in your other numbers.  the big HD fuel filter may be questionable?
Edited by CAL(KS) - 03 May 2019 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote calvin long Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 11:52am
Originally posted by CAL(KS) CAL(KS) wrote:
 <span style="white-space:pre">     </span>Part Number<span style="white-space:pre">     </span>Manufacturer<span style="white-space:pre">     </span>Wix Part Number
<span style="white-space:pre">     </span>079352 <span style="white-space:pre">     </span>ALLIS-CHALMERS<span style="white-space:pre">     </span>51133   <span style="white-space:pre">     </span>
Thanks! As for the big HD filter ill have to pull it and see what the number is. Hopfully something available
